Window 10 32 bit can not install Microsoft Net Framework 4 help.
A search around interweb shows up this if you haven't sorted already:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version and ...\v4\Client\Version need editing to 4.0.30319 with elevated priveleges before attempting to install. Install then change registry values back afterwards.
