lost wireless connection help req.
  • markybrfc
    • 12
    i have a belkin router and hp laptop everything was working fine then i lost wireless connection.on the laptop there used to be a blue light on when wireless was enabled but now it stays red as if it was on the off position,i no longer have the disk for the router or i would try to install i,do you think that i may have lost the software for the router or is it maybe just knackered?i am using a cable from the router to laptop at the moment which is fine untill i remove the cable then i lose cnnection any help would be appreciated thanks..
  • faum72
    • 90
    you could get any drivers from Belkin support site online, but usually you don't need drivers for a wireless router, only the drivers for the network card or usb on the laptop...if the lights changed too red on the wireless on the laptop this could mean either the drivers have currupted ( so u'de need too go too the support website for the manufacturer of the laptop and reinstall ) or the wirless network hardware on the laptops developed a fault (which happens ) the easist thing too do there is get a wirless card or usb dongle too replace the laptops wireless unless you have someone too take the lappy apart and replace the internal card, or pay someone at a shop which can be pricey...
    as for the roughter have a look at the back and see if there is a reset button this may help retting and ironing out a firmware fault, but from what you've said it sounds like the problem may be with the laptop:-(if the wirless isn't turning on...hope this helps abit
    • dik
      • Apr 2009
      • 955
      I had something similar and it turned out to be that a keyboard shortcut ie control+f5 or similar had accidentally been pressed which disabled the wireless, worth a look on your keyboard to see if there is a antenna symbol on any key
      sigpic another happy customer
      Sent from my keyboard using fingers to type
      • marginal
        • Feb 2010
        • 399
        You don't need software for a router.
        You can access the setup page of any router through its IP Address.
        Have you tried repairing your internet connection by right clicking the small monitor on the taskbar and choosing "repair" (in XP, for Vista it is a different name)?
        If you still can't fix it after all the suggestions here, it needs troubleshooting.
        I could do that for free over the phone, just let me know, I can call you too if it is too expensive to call long distance for you.
        Good luck.
        Est Modus in Rebus !!!
        • bob1303
          • Feb 2010
          • 11
          Mark try going control panel network connections right click on your wireless go to properties second tab along should be wireless net work make sure the let widows configure my network is ticked hope this helps
