Windows 10 doesn't recognize headphones when connected to front
  • EricaR
    • Aug 2020
    • 11
    When I connect headphones to the front input of the PC, Windows doesn't recognize them as headphones. When I press the icon next to the clock, there are realtek speakers there.I want to switch between headphones and speakers without having to always remove and insert the headphones in the front jack. How can I do this?
    Got same ‘problem’ i tried speakers in front socket nil poi
    almost like the switch in front panel faulty
    • Leslie Simpson
      • Sep 2020
      • 25
      Perhaps the front connector is not simply plugged into the board. I had this in my old PC. We suffered until one master found the problem. And now we have a laptop. There is no such problem.
      • Ignelio3
        • Jun 2020
        • 6
        Hey, have you tried to enable in realtek hd audio manager, where is the analog section little folder icon. Here is option enable auto popup dialog when device has been plugged in. Try this one maybe it will help.
        • toyota123
          • Sep 2019
          • 440
          check the connection in case ... and check if the connector is enable in device manager ...
          DON'T FORGET TO USE BUTTONS BELOW REP & THANKS
