toshiba A300 bios locked and HDD
  • jjrp255630
    • Jun 2009
    • 1948
    hi, i have this laptop, but children play with him and put a password in a bios and on HDD, its possible remove both?
  • ManofScience
    • 650
    ONLY by using the inbuilt software that comes with it. I've recently had this where someone had used the built-in toshiba software to add passwords. lucky, when i got it he remembered the password and i was able to take it off.
    you better ask your 'kids' if there remember it. Otherwise, you could try dismantling it, removing the cmos battery for a while, but i'm not sure this works
    • eurovox29
      toshiba a300 bios password
      i took the cmos battery out but it did not make no difference. the password remains at startup, no effect, just detects the bios battery failure..
      • robbo1
        • Apr 2010
        • 153
        This might work (it's for the A200 but should be similar)
        Remove the battery
        Remove the memory slot cover
        Remove the memory
        Look for a small 'W' shaped area and short it against the case.
        • robmulally
          • 16
          Each vendor can be different.
          Do you know the make and model of the MB?
          Try contact the support for both via email or phone.
          Becarefull of ebay scammers selling online tools that the hardware companies can provide . (esp if you are under warranty.)
          • misko_ser
            Damn, I think that you absolutely have to know the passwords.
            Sorry
            • jjrp255630
              • Jun 2009
              • 1948
              Remove the battery
              Remove the memory
              thanks to try help but in A300 dont have the W
              regards
