Panasonic cf52 BIOS password
  • ivoc
    • Aug 2020
    • 4
    Hello
    I'm in need of a password for this laptop to enable boot from cd-rom. Can anyone help me with this? Cant find anything online
    Model NO. - CF-52REN76Q2
    Serial NO. - 1ETCA12304
    Thanks in advance
  • aby23
    • Mar 2019
    • 286
    try this code Bro
    3maec37f1v
    press thanks and rep if i helped you
    • crouchinggerbil
      • Aug 2020
      • 4054
      Originally posted by ivoc
      Hello
      Thanks in advance
      OR YOU CAN TRY
      Bios password cannot be removed by just reseating the cmos battery. You might need to short the board to reset the bios password. Please take not that this is a critical job you need technical expertise in doing this.
      Follow these steps:
      Remove Laptop Battery
      Remove Memory Cover
      Spread spring clips to outside and
      pull out RAM memory
      Remove clear vinyl label opposite RAM memory slots
      In the upper left corner you will see JOPEN1 with a white silkscreen square
      Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
      HaynesPro 2026 online + AC/ Delphi 2023.20 available, message for where to get them!
