black screen on medion laptop
  • tamgunner
    • 691
    hi guys i have just replaced a dc socket on a medion laptop i have reconnected the internal cables and put it back together it powers up but im getting a black screen u can just make out the windows xp logo and thats it.
    any ideas how to sort it?
  • NHRA21
    • 6
    If it is a really dim image, you are having a backlight problem. This tends to be a small board located on the bottom of most Lcds called the inverter board. There shoul be two silcone wires coming out of a plug on it. Sometimes these plugs are keyed so that you can put them in upside down, but when you do they do not make contact. There is also a harness that goes from the motherboard to the inverter - make sure there are no bent pins. Lastly, there should be a small switch that detects that the screen is closed. On some laptops, when this pin is depresses it turns off the backlight.
    • caveman_nige
      • Feb 2008
      • 4920
      or the backlight inverter itself could well be dicked, its not unusual. On it there will be a part number, whack that number into google and you should be able to find a replacement backlight inverter.
