help needed
  • aidy preston
    help needed
    file:\windows\system32\drivers\wdf01000.sys
    status: 0xc0000221
    info: windows failed to load because a critical system driver is missing or corrupt
    this comes up everytime i try to boot up was using xp but run windows 7 for a short time
    how do i repair it as the windows disk wont do it from the repair
  • cunny
    • 4915
    Have a read here A Stop: 0xc000026C or Stop: 0xc0000221 "Unable to Load Device Driver" Error Occurs When You Start Windows XP
    Am i right in saying it does this under windows XP and Windows 7 (both OS give you BSOD (blue screen of death)
    • aidy preston
      no blue screen its white with black wrighting
      • nano_watt
        • 21
        Yes there is is such a thing as "white screen of death". Have a read of this White screen of death - Wikipedia, the free encyclopedia
        If you are not savy with computers the easiest solution is to reinstall the system and save loads of time. If you have data worth keeping then connect the drive in an other computer as a slave and take your data out and then do a clean install by formatting and partitioning the hard drive. Good luck!
        • ManofScience
          • 650
          eh? does this mean you've tried and it didn't work?
          either way, get the disk and follow this guide : How to Perform a Windows XP Repair Install
