software startup problem
  • nialler
    • May 2010
    • 141
    hi lads,
    i have a problem with a piece of software. it is not starting up for me. it seems to try to start up as it goes 95% of the way. ther is a particular piece of hardware which it recognises but then the fun starts. in order for this program to start it nees a third party piece of software called at&t natural voices. i think a licence issue with this might be the problem. it will not start without this....
    is there anyway on the machine where i can see if this is the problem????
    it does not give me any fault on screen!!
    cheers in advance guys.
    nialler
    Dont forget to say thanks
  • Canker_Canison
    • May 2010
    • 3904
    What's the software you're trying to run?
    Canker
    [COLOR=Green]
    • nialler
      • May 2010
      • 141
      bit of long story canker mate. we recently purchased software form a company going under. i have used it in the past and is has worked well. think is i had to clone a drive to copy over form 1 machine to another. original machine has working version but clone wont fire the software up. ???
      • Canker_Canison
        • May 2010
        • 3904
        Have you tried looking for a patch?
        Sounds like it's failing a hardware check. As you suspect it might be a licencing issue. Think of it like Windows, a product key is used which is then tied to the machine. If you change the processor Windows won't work correctly, even if it's a straight swap.
        Have you tried contacting the software developer? Claim you have taken over part of the company & are having system problems.
        Canker
        [COLOR=Green]
        • nialler
          • May 2010
          • 141
          spot on mate. i contacted at&t directly claiming i had a failure and had to move the hard drive. asked him if i could have a licence reissued??
          he told me almost exactly what you said. a moved hard drive will cause a licence failure. the answer!!! give us money and we will give you licences. worth a shot.
          cheers for the help mate
          nialler
