Notebook password problem
  • maff
    • May 2010
    • 15
    Ive got an ITRONIX IX250 notebook and when i try to boot it asks for a password.the ones ive been given wont work. Is there any way round the password so i can put another o.s on? cant get into the bios or anything. Or do i need another HDD?
  • beetlejuice_85
    no BIOS pass is bad. I know, the battery of the board can remove and the BIOS pass should be away. But I self try it not, I read about this. Another way is also interesting for me.
    Sorry for my bad english
    • cabaniss34
      • 7
      Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. ... Itronix GoBook (IX250) BIOS 2.04. Price: FREE
      • cabaniss34
        • 7
        Note: Use at your own risk or just remove bios battery 15/20 seconds and do not pull battery fully out and that might just do the trick but be very careful !!!! Opening laptops can be very messy if u do not know what you are doing !!!!
        • royalreef
          I would recomend you to get the manual for the pc first it will give you step by step to remove the battery I had done that for many computers and everything work perfectly fine after I put it back together.. JUST be patient....
          • unkunde
            Most BIOS?s have a "Master password", but some companies chenge them to there own. With a little luck it works on your Notebook.
            http://www.xs4all.nl/~matrix/mpwlist.html
            Good luck!
