XP System Recovery problem
  • jonnyluvrod
    • Apr 2009
    • 56
    Hi all.
    I'm trying to save a friends laptop.
    It won't boot from the hard drive. It gives the error - 'windows could not start because the following file is missing or corrupt'
    So I've attempted to boot from CD to start the recovery console.
    I've pressed 'R' to start the recovery when prompted but once windows reads from the disc, after a minute or two I get a blue screen saying windows has shut down the computer to save damage.
    I can't get past this step to run a chdisk or replace the missing files so it will boot.
    Is the Hard Drive knackered?
    Any help or advice is greatly appreciated.
    Thanks...
    Make something idiot proof and someone will make a better idiot
  • robbo1
    • Apr 2010
    • 153
    This is usually a corrupt boot sector and gives a black screen refering to ntdlr missing. What type of laptop is it (brand, model...) It may have a recovery partition.
    • jonnyluvrod
      • Apr 2009
      • 56
      Thanks for the speedy response.
      It does come up with NTLDR missing message when attempting to boot from HD.
      It's an Acer Aspire 3004 WLMi.
      • robbo1
        • Apr 2010
        • 153
        This should have a recovery partition. On boot up, when the Acer splash screen appears, press F8 for advanced windows options and look for the recovery or rebuild options.
        But, running this will return the laptop back to factory settings, so all data saved will be lost and a fresh windows will remain
        • jonnyluvrod
          • Apr 2009
          • 56
          Thanks for the advice mate.
          I've brought up the menu before using F8 and it doesn't give me an option like the two you mention, only the following:
          Safe Mode
          Safe Mode with Command Prompt
          Safe Mode with networking
          Enable boot logging
          Enable VGA Mode
          Last known good config
          Directory Services Restore Mode
          Debugging Mode
          Disable automatic restart
          Start Windows Normally
          Reboot
          Return to OS choices
          I'm of the opinion that the HD has had it.
          Thanks again...
