laptop wont boot
  • faulks6164
    • 55
    laptop wont boot
    Hi all I have just reinstalled windos on my sons dell 1501 inspiron laptop, i was installing all the drivers when the laptop just froze so I turned it off & on again but the laptop does not start just a black screen, I cannot get into anything .. Any advice would be appreciated.
    Many Thanks
  • varmab
    • May 2010
    • 116
    Many Thanks
    Try removing the battery and then back after some minutes without the battery charger.
    • paper
      • Jul 2010
      • 11
      Assuming the machine starts....
      Hit the F8 key (keep hitting it)
      You (hopefully) will see an options screen after a few momments.
      Select VGA mode from the list and reinstall the graphics drivers.
      Hope that helps.
      Paper
      • faulks6164
        • 55
        the power light is on but it does not boot at all ,tried a new hdd same thing .
        All help appreciated
        • TheOnePT
          • Jul 2010
          Try to boot a linux live distro like ubuntu and then post your results.
          • Theo1606
            • 36
            What does not start the notebook or the Windows ?
            What bevor you install Win new .... start it ?
            • Canker_Canison
              • May 2010
              • 3905
              Does it boot as far as the Bois post screen?
              If it fails to even get to the Bios you will need to check the memory, HDD connectors, the Bios battery. If you can reset the bios at the same time it will help.
              It's also possible the processor has died. Has it ever overheated? Or the fans speed up alot?
              Canker
              [COLOR=Green]
              • kreller
                • Aug 2010
                • 49
                I have tried something like you, I took out the graphiccard and cleaned the small contact surfaces and then i run again. Maybe its dust.
                • popeye05
                  • 18
                  try with an external screen
                  • petenyc7
                    • Aug 2010
                    Make sure there is nothing connected to USB drive such as usb memory stick or external hard drive. Sometimes the first boot device is setup to usb and that will cause the black screen and blinking cursor in the left upper corner.
                    • chickenboy
                      • Apr 2010
                      • 8
                      If it doesn't POST, no display on external monitor, your board is screwed.
                      • mbsobrinho
                        • Jul 2010
                        • 50
                        If you are unable to see the post screen, you may have to update bios to solve the problem. See the link below:
                        如流,是百度旗下新一代智能工作平台,以知识管理为核心,构建AI时代工作流水线,助力企业实现提效创新,赋能企业在智能经济时代打造核心竞争力。
                        • rsebastian
                          • Jul 2010
                          • 13
                          Hi faulks6164 Did you check the Bios?? Sometimes the problem is because the Bios doesnt have assigned the hard drive to start all the computer.
                          So try this. Turn on ur laptop and at the same time press the F2 buttom. If you get access to the Bios, check that your hard drive is set up as primary IDE, if dont you have to do it, because maybe your laptop read ur cd-rom first or a usb port.
                          I hope this information will be useful for you
                          Cheers
