FORMATING PC
  • femmym
    • Aug 2009
    • 163
    FORMATING PC
    im trying to format my pc at the moment , the problem is when i get to installing windows on the list and the time says 32 minutes left , the computer keeps freezing dosent matter what type of format i do it still does the same once it reaches 32 minutes it freezes again and it wont go no further, i would be very grateful if anyone could offer any help or advice what might be the problem i would be really grateful thankyou . im using windows XP home edition disk to format my other pc .
    femmym
  • dik
    • Apr 2009
    • 955
    Maybe your windows disc is fcuked, can you get another copy - find one on the web & try that
    sigpic another happy customer
    Sent from my keyboard using fingers to type
    • femmym
      • Aug 2009
      • 163
      maybe there dosent seem to be any scrathes on the disk of any sort seems strange
      • hcip
        • 1961
        or maybe CD drive, hardisk, memory etc
        or it is the same with my one CPU that I salvage. but it is only take 10 min and hang on during installing all function doesnt work even the power switch, I need to unplug the power to off and replug again then the power switch work. but when I attempt to install again the windows, it will hang again after 10 minutes, I choose to buy a new one
        Stupidity is not a disease, because there are no existing hospitals for Idiots!
        • ManofScience
          • 650
          could be memory - it's trying to extract something and it's hanging.
          • femmym
            • Aug 2009
            • 163
            i have tried that and no luck thankyou anyway .
            • femmym
              • Aug 2009
              • 163
              il have a look at the memory see if there is a problem with that thankyou .
              • otobots
                • Jul 2010
                ok...try replace ur hdd sata/ide cable...hope that will help u
                my xperience, if my mobo support sata 3 and my hdd is sata 2, dun use sata 3 cable to format the hdd, use sata 2 cable instead.
                • hcip
                  • 1961
                  Get a memory from other goog PC or vise versa
                  if your memory is good, it 100% problem with your Main Board
                  • dasteph
                    • 1293
                    as dik sugests try to get another installation disk, the data on the disk could be corrupt which does not mean the disk is scratched.
                    • nesa64
                      • Jul 2010
                      • 4
                      check the power of PC
                      • bgd_ct
                        • Jul 2010
                        • 51
                        when windows is installing, it uses al lot of the RAM memory, so if a small small area in the RAM is bad it will frezze, also when other erors appear, like "win cannot find the xx file, please insert the disk labelled win xx and press ...... " , the same problem
                        • ASLO444
                          • Jul 2010
                          • 5
                          femmym
                          You haven't said which version of windows you are trying to install femmym (only what your using to format). If you are trying to install win vista or win 7 your computer may not be up to it m8 as they need plenty of ram and fairly fast processor. Please tell us more about your puter.
                          • paper
                            • Jul 2010
                            • 11
                            Boot the PC using a DOS or ERD disk, then copy the i386 folder from the CD to the hard disk, if the disks bad you should get a file copy error.
                            If not navigate to the i386 folder on the hard disk and start the install using winnt.exe
                            Hope that helps
                            • lmsvvavr
                              • Jul 2010
                              • 569
                              Formating PC
                              femmym
                              Hi!
                              Hi had the same problem many and many times...
                              By experience and like has been said here already, there's a good potencial that your memory is no good, or your windows disk...
                              However you should do something else before made your mind up....
                              Take you memory out and give it a good cleaning, oxidation can create a lot of troubles....
                              Remove all cards from PCI slots, AGP as well(If you are able to use the onboard one-if available), got to the bios and disable all on board hardware, like on-board sound cards, lan cards etc... leave the graphics if you are going to use it...
                              Try to install after all that...
                              Each case is diferent, but one of this things can be causing you problem...
                              Hope you get successful...
                              Hit Thanks if helped you!
                              Thank You for the help!
                              "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
                              http://www.youtube.com/c/LMAutoRepairs
