XP Password
Hi!
Don't panic, is deadly easy to sort that out...
Like has been said here already, you can try:
When booting press F8 and start xp in safety mode, then log in in the administrator acount, go to painel control and users and reset the password from the acount you want.
If the acount in use is already, the administrator one, you wont be able to do this, however you can sort out in another way...
You can like z786 said use opcrack, personally i had a few intances where opcrak was not able to retrieve the password, and i found this one which i found more reliable...
RapidShare: 1-CLICK Web hosting - Easy Filehosting
The latest version of this is here:
Just burn the image into a cd and boot from...
Folow the steps, at the step where he will ask you if you want change password or reset/clear, choose reset/clear, works better...
Hope this help...
Hi!
Hope this help...
