hi there hope peeps can help i have a samsung r410 the problem is when i turn off/ standby the laptop it will not turn without the charger plugged in, i think its got nothing to do with the battery coz when i turn it on with the charger i can un plug it and use the battery thank you in advance....
HELP!! laptop works with charger plugged in only so annoying
You may want to check your bios configuration, maybe that could help
Remote support for advanced Car & ATV dump mods
Volvo config mods, dump repairs (CEM, ECU, SRS, ICM, DIM)
ATV/SSV ECU tuning & limiters (Vmax, Nmax)Comment
Right when you turn on laptop, when windows are not loaded you should see something like "Press F1 for setup" or something like that, it may be not F1 also.... But i'm not sure if there's a solution...Remote support for advanced Car & ATV dump mods
Load into windows, set power saving options to suit your needs, disable sleep mode ect. Also boot into the bios and check there is nothing there that could be causing the laptop not being able to wake from sleep mode.hi there hope peeps can help i have a samsung r410 the problem is when i turn off/ standby the laptop it will not turn without the charger plugged in, i think its got nothing to do with the battery coz when i turn it on with the charger i can un plug it and use the battery thank you in advance....sigpic
Thanks ezzda1, with a slight mod this worked on my new Toshiba laptop.....
plug the charger into the laptop without the battery connected,
turn the laptop on, when it's finished starting up, put the battery in,
shut it down, remove charger and try to start on battery.Comment
