hi.... tryingto install hardware pci multi:10 controller ....says wizard found new hardware.....when i press next it goes through some rigmaroll then comes up......system cannot find the file specified.....can anyone help
You have to tell it where the drivers are located. Been a while since I've installed any PCI cards, but you either install the driver disk then the hardware. Or you need to manually locate the correct driver package on the disk, then put that path into the found new hardware wizard.
