Laptop keeps freezing????
  • New2Eurovox
    • 14
    When i plug in my usb HDD or an SDcard my laptop recognises them and says they are working properly
    Then when i start to transfer/copy files off or onto the HDD or SDcard i will either manage to get one file done or it will stop halfway through and cause my whole screen to freeze
    I then have to turn it off and re-boot all over again
    Its doing my nut in as my gf has requested a load of albums and i can put them onto her memory stick
    Any ideas whats up??
  • cgscott
    • 3513
    You tried reformating the cards before you transfer the files over?
    Patience is a virtue.
    • barrowmanandrew
      • 3427
      operating system?
      stupid question, but you have tried diffrent memory cards??
      • New2Eurovox
        • 14
        It happens when i use either of my USB HDD'S and both my SDcards and also 2 USB sticks
        I have formatted the USB sticks on my laptop and the problem is still happening
        Im using Vista Home OS
        • barrowmanandrew
          • 3427
          i'm no expert but try,
          control panel, select classic view
          then open device manager
          look down the list
          check for universal mass storage device..
          if anything has a red cross next to it, then delete it. when you plug devices back into usb port,
          windows will re-install drivers.
          worth a shot....
          i had exacltly the same problem with everything i connected using usb port,
          i.e. camera , printer
          worked for me
          • drwhom
            • May 2010
            you might want to try using those thru a powered usb hub
            ,inexpensive and worthwhile
            • plato49
              • Aug 2010
              Try re-booting after ok message before copying.
              Try reformatting and changing FAT to FAT32 or vice versa
              • mak21
                • 27
                Try to load BIOS default first, and also try to copy in safe mode (press F8 while booting and chose safe mode)
                • yosarian
                  • Sep 2009
                  • 75
                  disable antivirus, and try
                  Maybe you have some virus on that and it will freez 99% shure
                  BR
                  • joroboichev1
                    • Jul 2010
                    • 7
                    start up in safe mode, you can do this by tapping the f8 key
                    • starsky
                      • Jul 2010
                      • 35
                      Try reformatting the cards
