burning dvds
  • tj28
    • 14
    burning dvds
    hi i was wanting a bit of advice on how to burn dvds films i was trying with nero but couldnt manage it it worked once but the disc would only play on my pc not in a dvd player any info much apreciated cheers,i was trying to do it on windows media pllayer but that wont give me any options for burning dvds it only lets me burn cds,i have just instaled the dvd rewriter
  • mm009b
    • 221
    hi mate i use any dvd and clone dvd you can try download it from web at least you will get 21 days trial cheers mate
    • tj28
      • 14
      cheers
      cheers m8 will give it a try how long does yours usuall take to burn a dvd
      • andy4
        • 1125
        tj28 i use nero for burning have no probs how new is your dvd rewriter your laser might be out of line
        WIGAN ATH the BLUE BRAZILIANS
        DWSTADIUM the theatre of SCREAMS
        <<<<--------if i've been helpful hit the Thanks button
        • tj28
          • 14
          iv got a copy of nero 6 there,my burner is a few years old now i took it out my last pc and got a guy in pc shop to fit it total waste 25 quid it only took him 2 min
          • zedhed
            I would recomend DVDfab for Burning and Converting DVD's etc.
            • boodykaka
              • 29
              You can also use dvd shrink for this its a free program
              • andy4
                • 1125
                tj try nero7 that should do the trick
                • tumi999
                  • 5
                  i recomend Nero 7 or Movavi because thats wat i use on daily bases.
                  • Street Hawk
                    • 156
                    Hi, my recommendation would be a program called "ConvertXtoDVD" this little puppy converts the film and burns the film to DVD no problem. the benefits of using this program up against many other programs out there such as Nero, is that
                    A). ConvertXtoDVD uses less resources when converting & burning, so you can do plenty of other things on your pc without CPU lag
                    B). it take approx 1hour or 1 Hour 20mins Max to convert & burn a film to DVD
                    C). you can make your own menu's and enter subtitles in with the film before burning.
                    bottom line its simple to use, fast & doesn't hog system resources!
                    I would give it a 10 Star Rating! the only thing i ever use nero for now is burning music. and my advice if any of you are using nero 7 get rid of it! its got to many bugs in the software that fails the burns!
                    Good luck
                    Street Hawk
                    • pooluop
                      • 41
                      convert with converter to dvd 3. takes 25 to 35 min to convert to TS file then find the file. drag in to dvd shrink 3.2. then this will be a( i s o) file. then burn. use imgburn to burning dvds.
                      • bondie
                        hi, where can i get convertxdvd from i use roxio and its slow as f**k.
                        • caveman_nige
                          • Feb 2008
                          • 4920
                          VSO Convert X to DVD
                          try this one mate..
                          RapidShare: Easy Filehosting
                          it will convert a .ts file straight onto a DVD format, i use it all the time..
                          • dasteph
                            • 1293
                            nero will burn dvds if all the files are placed in the ts folder only and burned at iso level 2, also use rw discs till you get the hang of it as this will stop the production of coasters as rw discs can be earased to try again or you can go to http://www.videohelp.com/ and use the guides on dvd burning
                            • pooluop
                              • 41
                              download converter to dvd 3 from demonoid .com or mininova.com.(with keygen.)
