Winxp Pro
  • siddler
    • 7
    Winxp Pro
    Hi all.....My 1st post on this forum.
    Some times when closing pages the mouse locks and changes from the arrow pointer to the glass symbol which hangs.
    Hitting ctrl,alt and del keys to bring up the task manager to which appears but still stuck with with the glass symbol?.
    I have to switch off the machine and power up again,the problem only shows from time to time,any help would be appreciated.
    siddler
  • Dreamer
    • 2020
    Is is probably happening with the same program all the time.. Try uninstalling and installing the program again.
    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
    • smokey_jnr
      • 380
      what you need to do is to check what processes are running and what is either taking the most CPU or mem usage. start by killing that process and searching google to see what it is..?
      when the task manager comes up a it may be slow to respond but you will still be able to click on to the tabs...
      • siddler
        • 7
        Hi Thanks for prompt reply I will check out what you advise and advise you ...I think It started playing up with a update to IE7 from Microsoft.
        Thanks.... siddler.
        • siddler
          • 7
          Hi Dreamer,Thanks for the info,I think it came about from MS updates to their browser...I think I will take the upates off one by one and see if thats,s the problem.
          Thanks siddler.
          • smokey_jnr
            • 380
            try looking on ms website and finding the KB no: ie7 then if you go into windows folder and enable the hidden files you should see all the installed patches, and then uninstall the one for ie7
            i think it's this one...
            Update for Internet Explorer 7 for Windows XP (KB928089)
            • siddler
              • 7
              Hi I have found the problem, afile named "REALSHED" from a deleted program "REALPLAYER" was culprit don't know why it was left behind when the prog was deleted...I had to boot into save mode to get rid of it and the same file was in a "Prefetch" folder.
              Thanks for all the advices.
              siddler
              • peggimon
                • 10
                Hiya,
                this is a familiar thing when programs are unistalled, they always leave registry keys and files there..
                I use a small program called "Reg Seeker" and this gets rid of all the useless stuff in the registry...
                Hope this helps in future....
                • siddler
                  • 7
                  Originally posted by peggimon
                  Hiya,
                  Hi, Thanks for the info yes you are right I have a program called 'Total uninstal which is used'.
                  Thanks siddler
                  • dasteph
                    • 1293
                    try revo uninstaller it takes out the software and any leftover keys in the registry!
                    • dctyper
                      • 2539
                      sounds like your memory is getting used up, try ccleaner or any of the suggested.
                      what is the ram on your pc? how much space do you have left on your hard drive?
                      do you have an anti virus running? these will all effect your performance
                      Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
                      previous life dm800hd and 500c on cable screw you nag3
                      • siddler
                        • 7
                        Hi Thanks for the info.
                        siddler
                        • siddler
                          • 7
                          Hi Ram is 2Mb Machineis ok now.
                          Thanks siddler
