lap top running slow to much cr.p on it help
  • evelyn2008
    • Aug 2009
    • 251
    hi can any body help me with any software that will clean my lap top up as it is rammed full of stuff and i dont know were to start ? i have tryed deleting which i thought was most of it but it has'nt even touched it and is now running so slow . i have a dell inspiron and really could do to taking it back to when i first bought it but dont have a back up cd and the last time i tryed it did.nt work . does any body have a dell inspiron lap top that has taken it back to factory setting and it worked that can take me throw to sorting mine.
    tar
  • Adi1980xx
    • 28
    Ccleaner is a good tool
    CCleaner - Optimization and Cleaning - Free Download
    • westcoastdodge
      • Apr 2010
      • 46
      Originally posted by CryptoWork
      Hi mate,
      I advice you to use Tune Up Utilities 2010, it is the best.
      TuneUp Utilities 2010
      i agree,tune up utilities 2010,you can get a 30 day free trial
      • sanscorp
        • Apr 2010
        • 75
        watch out with cleaning; if you don't know the option in the programs (tunup or cc cleaner) don't use them!
        The ultimate way to speed up your laptop is re-installing it completely, preferebly with Windows 7 (much faster!)
        Or consider upgrading the hardware (memory, hard disk --> SSD, VGA card?)
        good luck!
        • tooseyman
          • 26
          Personally I don't think windows 7 is much faster than Vista. My Dell Vostro came with Vista and a free upgrade pack for Windows 7 which took several attempts to install due to problems with the bluetooth and wlan drivers.
          There is usually a system image on most laptops so you can restore to factory fresh and clean all the rubbish from hard drive in the process. Just make sure you save anything of importance first .
          • Canker_Canison
            • 3904
            There's also Uniblue - Speed up my PC & Registry booster.
            These will remove unwanted system, backup & temp files. Codes are available via PM.
            You should also run an up-to-date antivirus & Malwarebytes.
            Canker
            [COLOR=Green]
            • popeye05
              • 18
              the best is formating the lab top
              start a news install
              • jtr8178
                • Jul 2010
                • 146
                tar
                Can you start Performance Manager and tell us how much RAM & CPU is being used when at idle?
                I find a lot of times the problem is a rogue program, spam, spyware, etc...
                • itr703
                  • 51
                  Yep; Clean install is the only way to be in charge;
                  Be sure to make a good backup before as you might need
                  some things afterwards ....
                  Regards,
                  ITR703
                  • autolockmasters
                    • Mar 2010
                    • 67
                    Before performing a full re-install you might consider cleaning your laptop from all spyware, broken/damaged registery entires and file system restore.
                    Try these few mothods and if they dont help then reinstall windows.
                    1- Run windows in 'safe mode' (Press F8 Key on system boot). Once running try to uninstall all unwanted softwares through add/remove programs.
                    2- Download and run registery cleaner. Many available of the internet for free.
                    Eusing Free Registry Cleaner: Safely scan and repair registry problems - Spyware FREE.
                    3- Download and run malware/spyware remover.
                    Malicious Software Removal Tool | Protect Your Computer
                    4- Run 'Disk Defragmenter'. In windows XP, Start->All Programs->Accessories->System Tools
                    After taking all these steps your laptop should run fine. If not then you need to consider full system re-install. If you do remember to make a backup.
                    Don't forget to say "THANKS", if my post helped you
                    • tooseyman
                      • 26
                      If your Dell is like mine, you probably have a desktop icon for 'Dell Backup and Recovery' which is used to restore it to factory settings. The factory image is usually on a hard drive partition called drive D:
                      Make sure you save any important stuff first as all data on drice C: will be lost and overwritten.
                      • pop_m
                        • 15
                        try running chkdsk on system partition (from command prompt, run chkdsk /F and then reboot as instructed), it does miracles. I had several cases of very slow response computers solved with that
                        So, run chkdsk several times (untill it fixes all errors) then try also defragmentation, and windows update. ~60% chanches to fix your OS without reinstall
                        • mpr3
                          • Jul 2010
                          • 11
                          Google and get Malwarebytes & CCleaner and look for WINaso to download .Run Malwarebytes & CCleaner then WINaso I use them all the time
                          Be Alert! The World needs more Lerts !!!
                          • Bflobob
                            • Jul 2010
                            I agree with those who have recommended running Malwarebytes, CCleaner and a registry program. I use Registry Mechanic, it's simple and you can always go back if something goes wrong.
                            • djsimo17
                              • Sep 2009
                              • 4
                              Type PC Pitstop on Google for tune up tips, it also cleans the registry, i have this on 3 pcs in the office and it has made a difference on performance, not that much about $20-30 well work a look
