program to large for mini laptop
  • super-cab
    • Jul 2010
    • 33
    On my Acer Aspire One, I've a program wich is to large to fit the screen.
    The screen is not high enough to show me the lowest lines of the program. (It's just 15mm)
    Screensettings i've changed, nothing works to get it vissable
    Has anyone got a trick to shrink the programscreen to fit??????
    Thanks, Rick
  • dasteph
    • 1293
    have you tried putting you screen cursor on one of the corners of your programe box and dragiing the corner toward the centre of the box this will reduce the size.
    • koossie
      • 6
      you can also try to set the taskbar different
      taskbar automatic hide function
      but it is a issue thats etka also have
      succes
      • super-cab
        • Jul 2010
        • 33
        Thanks for reactions!!!
        I've tried to reduce the size of the box as discribed.
        This is not possible, only move it around.
        Taskbar automatic hidding made half of the hidden visable
        Now I hope I find the solution for the other cm so I can see all buttons at the bottum of the program
        Rick
        • sanscorp
          • Apr 2010
          • 75
          Rick
          Sometimes it just won't fit, nothing you can do!
          try connecting an external monitor, set the resolution of the second screen higher and then try to resize the window.
          If this won't work then it's not possible.
          THE reason I dumped my netbook (mini notebook)
          • super-cab
            • Jul 2010
            • 33
            Oke, I hoped there was a trick or something.
            Saddly not, wich I already was affraid for.
            The mini notebook is so nice on location, instead of the 19" laptop on my desk.
            Thank anyway for reaction. I can stop searching no.
            gr Rick
