laptop will no boot
  • challah
    • 242
    laptop will no boot
    hello to all
    a mate gave me his laptop to try and fix
    it will not boot
    it starts off telling me that it cannot reconise the battery and press any key to continue then for a minute or so it appears to boot then the blue screen comes up saying
    unmountable_boot_volume
    stop: 0x000000ed etc
    i was hoping to reinstall the os but the cd does not seem to be working either
    is there any workaround for this eg connecting the laptop to my computer and reinstalling from there
    i would be gratefull for any help
  • Reapers
    • 242
    Please provide info on laptop type of laptop,os etc.
    Someone will have to open the case and check the hard drive.
    The connections ide/sata somethink has might have come loose i
    think.
    if your not comfortable doing it take it to repair shop or technician.
    hope it works out fine
    • dasteph
      • 1293
      Originally posted by challah
      hello to all
      it will not boot
      read the following it might help.
      STOP 0x000000ED UNMOUNTABLE_BOOT_VOLUME Error - MajorGeeks Support Forums
      • challah
        • 242
        dell inspiron 1501
        xp home
        thanks for the replies
        • challah
          • 242
          cannot use the fix on majorgeeks as the cd drive does not seem to be working or the system does not reconise it
          i tried to change the boot option to cd drive but it wont let me
          • dasteph
            • 1293
            depending on how old the laptop is there might be a recovery partition on the hard drive which you access at boot up by pressing f10 or f11 i can not remember which it is, it is on the screen as soon as the pc starts hope this is of some help.
            • challah
              • 242
              tried f1 to f12 no good
              • dasteph
                • 1293
                as you say your cd/dvd drive does not seem to work and you cannot change boot options in the bios and there is no recovery partition i think its going to cost to repair it.
                • ezzda1
                  • 172
                  restart your computer when you see the dell screen press CTRL+F11 follow the steps
                  • challah
                    • 242
                    tried 4 or 5 times no good
                    • ezzda1
                      • 172
                      with most dell laptops, to change the boot order you use the "U" or "D" button to move the higlighted device up or down the list in the bios.
                      maybe this will help
                      http://support.dell.com/support/edoc....htm#wp1055231
                      • subcriminal
                        • 17
                        Try removing the battery and power lead, hold the power button down for 10 seconds or so then refit battery and lead. If it sorts it, make sure you're running the latest BIOS A16 I think.
                        • challah
                          • 242
                          tried that no good
                          screen says bios revision 2.3.0
                          i have a nasty feeling my mate may have updated the bios himself and messed it up
                          i have tried everything suggested by the good people here and no good,i have also downloaded the manual from dell and followed the instructions from there no good,
                          it makes no sense the options that are are supposed to be available to me are not there
                          i think this will need something radical
                          any off the wall ideas are very welcome
                          • ezzda1
                            • 172
                            remove the battery and plug the charger into the laptop.
                            can you get into the bios by pressing f2? if yes its not too bad,
                            can you scroll through the bios pages by pressing alt & P?
                            if you can its not too bad.
                            page 2 has the boot options on it, highlight the one you want to boot from and pres U untill it goes to the top.
                            then save and exit.
                            if you can get into the bios but nothing in there is sellectable then it is probably a goosed bios.
                            • georgegt
                              • Apr 2010
                              • 179
                              ask your mate for bios update first but I have a similar problem with a laptop after a day without bios update he stat but freez on posttest and I open he back panel and ( I was lucky the bios chip have socket ) remove the chip and program with a programmer after that mine work perfectly
