connecting pc to tv
  • barrowmanandrew
    • 3427
    connecting pc to tv
    i have connected my pc to tv using an hdmi lead.
    i have done this because, i wish to use my pc on main tv now and again as i now have a wireless dektop.
    problem:
    when moniter and tv are both connected, i get moniter working as normal, desktop background on tv.
    if i disconnect moniter, all functions transfer to tv.
    my question is:
    is there anyway i can control which moniter is active without pulling vga lead in and out?
    thanks in advance..
    ps. i am using an acer aspire running windows vista...
  • dasteph
    • 1293
    problem:
    my question is:
    thanks in advance..
    i have a nvidia card in my pc with it comes a nvidia control panel witch allows me to set up multiple displays and lets me select witch displays to use.
    • barrowmanandrew
      • 3427
      thanks, i have nvidia control panel too.
      i can use to switch between moniters. but i cant get both moniters to work at same time?/
      is this correct?
      • Cronus
        • 692
        Under "Display" there's an option called "Run multiple display wizard".
        • dasteph
          • 1293
          is this correct?
          there should be a setting which allows you to clone your moniter desktop to your tv so both show the desktop if this is what you mean, i do this with my laptop if i connect it to a tv the only downside i find is the resolution on the laptop changes to the tv resolution but i think in the nvidia control panel you can change the individual resolutions for each moniter hope this is of some help.
