Hi i just bought myself an advent sienna 700 brand new but for what ever reason i had to reinstall windows 7 home premium using the product key on the laptop. after the installation i found it didn't install couple of drivers automatically including the ethernet and wifi cards so i havent got access to the internet from the laptop, ive looked for the drivers on the web but didnt find anything can some 1 please point me in the right direction thanks
advent sienna 700
You can get the drivers from the pci number. Read below for instructions.
Every device has a Vendor and Device id associated with it. If you can find this ID, you can find the manufacturer. In Windows it's easy to find the vendor and device id.
1. Open Device Manager (Control Panel>System>Hardware>Device Manager)
2. The hardware whose drivers are missing will appear as Unknown device, so it's easier to locate the device.
3. Right click on the unknown device and click on Properties.
4. Under the Properties window click on Details tab and select Device Instance Id from the drop down box.
5. You should see a code similar to this
PCI\VEN_8086&DEV_27DC&SUBSYS_30868086
&REV_01\4&1E46F438&0&40F0
6. The portion of the code highlighted in RED is the Vendor ID and the portion highlighted in GREEN is the Device ID. In this example:
Vendor ID = 8086
Device ID = 27DC
7. Once you have obtained both the IDs, proceed to PCI Database. There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.Comment
