HP laptop 6735s
  • mit2007
    • 162
    HP laptop 6735s
    Hello
    I have a laptop Hp6735s which motherboard has be come faulty.
    The laptop no longer start up. the caps lock light blinks 5 times and the front hdd/processors light blinks yellow instead of blue.
    I wanted to know where i can find a replacement motherboard not from Hp because it too expensive ?240. i am looking for one around hundred pounds.
    Regards
    mit2007
  • ciccio007
    • 9
    HP has many problems with the nvidia video cards, this is probably your problem.
    solutions are two
    BGA reflow ("cheap")
    BGA reballing
    reflow can do it alone
    • ss0000
      • Mar 2009
      • 151
      The HP dv series are the most common laptops with this problem. There are videos on utube where people have tried these diy solutions. I tried heating up the graphics card with a pen torch on a HP dv6000 which had the same problem. Worked for a couple of months then had the same problem. Replace the motherboard from ebay. I used copper sheet between the heatsink and graphics card, made about 4 holes on the plastic bottom cover near the graphics card and now its been ok for around 4 months. I mostly always put it on a cooling fan and on a table not on my lap!
      • ashp
        This laptop does not contain nVidia integrated graphics
        I'm sure this laptop has an ATI chip can anybody confirm this .
        Also do ATI chips suffer from this issue?
        pls get back to me soon
        • ss0000
          • Mar 2009
          • 151
          I think some of the motherboards may have the nvidia and some the ATi chipset. You might have to check the specific laptop to see which it has. I think the later ones had the ATi chipset. The DV6000 series HP laptops had the issue not just because of the nvidia graphics chip but it was also because of the design which caused the overheating so ATi chipset may also be affected if the laptops get too hot
          • mit2007
            • 162
            Do you think it possible to repair this laptop? or it it not worth it?
            this was my first laptop that lasted only under 2 years. maybe i should be careful when i pick my next laptop.
            • jtr8178
              • Jul 2010
              • 146
              Your best option at this point would be to purchase a used, tested motherboard off of eBay (or another source). Since you can purchase a good, quality laptop for around $500 USD, it might not be worth the effort.
              Or if you just use it for Internet, email, word docs, etc... Just get a netbook for around $150 USD.
