acer aspire erecovery password
  • larryoke
    • 404
    Hi all, I have an aspire 5315 laptop running vista, & I want to restore to factory settings, it's asking me for an erecovery password which I can't remember, does anyone know how I can get around this?
    Many thanks in advance
    Larry
  • ezzda1
    • 172
    its the same password you use to log onto windows.
    if you don't know it, then it's most likely not your laptop.
    post a picture of your receipt and i will tell you how to get round it.
    • ss0000
      • Mar 2009
      • 151
      are you sure you setup a password? if not then I think the default password is 000000
      • ezzda1
        • 172
        default if you don't have a password on your OS is leave it blank
        • chris31560
          • Feb 2010
          • 912
          yes that is wot i did when i was restoring my os, left it blank and that worked....
          A LITTLE THANX GOES A LONG WAY
          • manxspud
            • 1768
            Errr no its not. When you run the recovery for the 1st time it asks you to create a password. It can be anything you like. If you have run it and forgotten your password can't help. If you have never run it it will ask you to make 1, after making a password leaving blank would not run the recovery tool.
            Not helpful i know sorry.
            @manx
            • ezzda1
              • 172
              @manx
              I'm afraid you are wrong the password is the one you use for your user account,
              if you don't have a password on your user account then leave it blank.
              Reset to factory settings with vista [Solved]
              I'm not the only one who says that......
              • manxspud
                • 1768
                i have 3 acer aspires m8, 3 x 5920g, could not care what any body says, as i have used it time and time again.
                no more to be said.
                @manx
                Ps ..
                • ss0000
                  • Mar 2009
                  • 151
                  I think manxspud is correct, your erecovery password has nothing to do with your user account password as user accounts are optional. From my experience of reinstalling acer erecovery partitions the default password tends to be 000000 unless it is set by the owner the first time erecovery is used
                  • southbrook
                    • 97
                    I had a family friend bring their acer round to me as they wanted to restore it to factory settings but it was asking for a password. The shop they bought it from put the password on e-recovery so you had to take it back to them .....sneaky devils..
                    Anyhow...got round it by using a linux disc.... cant remember exactly which one....basically you boot to the linux disc and in linux you can browse to the file which holds the password info...sounds hard work but took me a couple of minutes. I got the answer off google.
                    Hope this helps
                    PSN id RISSIEN
                    • Angelazhang
                      • Oct 2010
                      It is easy to solve windows password problems if you have Windows Password Key.
                      • hugjam
                        • Mar 2009
                        • 46
                        i i use an acer 5920 that used to run vista.i now run ubuntu ,which is much better than vista.
