vista shut down
  • chris31560
    • Feb 2010
    • 912
    vista shut down
    hi guys wounder if anyone can tell me why my comp wont shut down the normal way ie. start button then to the rite options.
    restart
    shutdown
    log off
    when i press shutdown it goes to shutdown ie shuting down but just stays on that for ages and wont move, so i end up switching it off at the plug, i know this is not go to do but its the only way it will shut down, so anyone got any idea,s...cheers giuys.....
    A LITTLE THANX GOES A LONG WAY
    ah vista pish ive had the same prob on xp, havnt found out what causes it, when i happens i just reboot pooter and it shuts down ok, and its ok for a while after that, ( i havnt had any viruses when it happens ) try cleaning the reg with ccleaner and do a virus scan as a precaution
    • chris31560
      • Feb 2010
      • 912
      hi m8 yes ive done both of them but yet it still persists on only wontin to shut down at power plug, its a worry coz i know shut down by this method is not good for the comp in the long run....
      • enigmas
        • 22
        Give a try from command line:
        start > run or window key + r
        shutdown -s -f -t 00
        This will force shutdown, and will close any opened applications, if that works than you have an application that is hanging your shutdown process.
          if vista ( ) is the same as xp, ctrl+alt+delete brings up task manager you can see whats running in the back ground and can try disabling what my be causing it, you can also shut down from there.
          • chris31560
            • Feb 2010
            • 912
            hi guys i seem to have resolved the shut down prob, it shuts down the normal way now, there is however something els commin up on screen once system has booted it says sis control centre has stoped working, does anyone know wot that means and how to sort it, cheers guys...chris...
