the capacity on my hard drive
  • fearlessimon
    • 172
    on my hard drive i have HDD (C and DATA (D disk c has a total capacity of 37.80 GB and disk D has 111 GB is this normal as i have to save alot of my stuff on disk D if not how do i change more room to disk C .........have not long started learning with pc`s so any help would be great thanks.....
    Dont eat yellow snow
  • mairtin
    This is a fairly normal setup. Your C: partition will hold your Operating System files and your D: paritition is set aside to hold your personal files (downloads, photos, etc).
    It's a good idea to keep these seperate in case you need to reinstall your OS, that way you wont lose any of your personal data.
    When your saving stuff browse to a folder on your D: drive or create a shortcut on your desktop to a folder on your D: drive, open it and save files there.
    Cheers,
    Mairtin
    • peggimon
      • 10
      Hi,
      I would follow the above advice and leave it as it is...
      The only way to create more space on your C: drive is to delete the partitions and create new ones, this would mean you loosing all your data and having to re-install the OS...
      There are 3rd party applications that say you can change your partition sizes without having to re-install, but be careful in case you loose it all anyway...
      Cheers..
      • Danril
        • 122
        There's no real need to change the size of your C: partition given its current size. You want your C: drive to have a nice bit of space free to help keep it running smoothly.
        I have a partition on my hard drive containing my OS with 20Gb for the C: drive and 80Gb D:drive. I've then shoved an old hard drive in my tower and have a couple of external drives. My aim is to have at least 3 copies of all my important files in case of failures. Overkill I know but better safe than sorry, plus you can then lend out an external to pals etc. The external HD's are only in use periodically when I want to back up or use the files that aren't on any of my internal drives.
          external hd
          get an external hd fairly cheap nowadays and you cant lose any data(crashes etc)
