Hello my external hard drive was dropped on the floor and now its making a sound like a scratched record, its not been recognised by my p.c either, is there anything i can do to recover the data ?
how to recover data from dropped hard drive
First i would open up the enclosure and check all the wires are still in place the noise you are getting could be a wire has come off and the drive is not getting enough power.
If all internal wiring is ok you have a bigger problem as most hard drive repairs and information recover is expensive as it is a specialist process working in a dust free clean room.
If you do attempt to dismantle and inspect your drive at home you will need to create a dust proof area most people would use a large size clear plastic bag and work within this to limit dust .But it wll still limited to what you can acheive .
Good Luck -
If your drive is making a cyclic sound it's because it has a mechanical problem. So the only thing to do is send it to specialized lab that will be able to recover your data. Don't open it by yourself, i'll only make things worse.
Here in France for this kind of problem you'll have to pay like 1000-1500 ***8364;Comment
have you try to disconnect the hardisk and plug the enclosure to PC without hardisk?
if the USB module cannot detect by PC then replace the enclosure. or try to change the crystal of enclosure. I have this kind of problem before. if the problem is realy in hardisk, maybe the heads was damage and it cannot read the data
in my area there are so many shop that recover the data for this kind of problem in a cheap price ( 350 pesos/ 7.29usd)
not all 100% of data can be recovered but almost 90%Last edited by hcip; 23 December, 2010, 00:15.Comment
I agree with this If the drive is making a clicking noise then it has the "click of death" google for more info on that! The drive has a mechanical failure It has been done a few time freezing the drive might enable you to quickly pull the data off the drive. Either way the drive is dustbin job wether you get the data off or not The only way to recover the data other than above is the photograpy the disk service very very expensive ;-(1st UN-Official Meat-Head Fan Club Member (banned
) Comment
if your proficient with small screwdrivers and have another harddrive (same make model) I would be tempted to open up the broken one look for damage and see how the platters are held in place.... Suggesting this as a last ditch solution before throwing it in the bin or sending off to a data recovery place.Comment
i had the same prob a while back with an external hd,,had so much stuff on it i was in a right mess,,,basically recover my files proggy recovered most of the drive it was clicking like mad,,only problem was once i saved the contents and tried to view them it wasnt having any of it,,,i lost so much stuff,,,,the best advice i got was to ~~~~ the hd in the bin and in future save all data/files etc to dvd disc and put somewhere safe,,this was from the owner of a pc shopThe control of information is the consolidation of power
?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
IF I HELPED HIT THE THANKS BUTTON
hi. im from philippines also. P350? can u pls recommend the shop that repaired ur hdd? Thank u so much!have you try to disconnect the hardisk and plug the enclosure to PC without hardisk?
not all 100% of data can be recovered but almost 90%Comment
Just running it through a data recovery program might not be the answer, would depend on how damaged it is, clicking ect would indicate bearing/platter issues. If the surface of the disc is also knackered then its screwed.
Conect the drive to a pc without the enclosure (hopefully the enclosure would take the brunt of the impact)
If it still registers in windows you could be in luck. The run some recovery software, i used EASEUS Data Recovery Wizard Professional v5 5 1 last time i had some recovery to dosigpic
