pc problem
  • irishbluestaffy
    • 611
    pc problem
    hi all i have a strange problem i have a gigabyte ga-964p ds4,4 gig extreme ram,e6700 cpu,600 Wat psu,the problem is when i turn my pc on in the morning it comes on fine but if i shut it down i cant get it back on the fan lights come on with the fans working but it doesn't start,doesn't matter how many times i try to start it it will not come on so i have to pull the power plug out and leave it for about a hour and then it will start,iv stripped it down and back again still the same,and iv reformatted it,problem still there.any help would be very great full,thanx
  • Reapers
    • 242
    possibly a bad psu.(if possible try another working one)
    youll have to go through everything to check whats faulty because
    it could be a number of things that could cause them things.
    check the bios settings
    check ram
    check all the connected componets that the psu is connected if any are faulty.
    check to see the motherboard is connected properly on the front panel so to
    see if they are working ok
    check the power options on the operating system.
    • agronn
      • Dec 2010
      I had same problem you have a problem with your power supply
      • Hairlocks
        • Dec 2010
        • 9
        I had a problem like this. Mine was the chipset over heating on the motherboard, pointing another fan at it solved it.
        Does it even show the BIOS on the failed attempt to boot. If not it is definitely a hardware problem.
        • smihunga
          • 4
          Help please my laptop cannot log on
          My Toshiba U400 cannot start, I have a screen password which takes me to windows log on. My password is not being recognised does not even type anything but when I press enter there is a noise which come up but of course since the password is not entered I get that annoying sound.Is there a way I can reset the bios
          • irishbluestaffy
            • 611
            when i turn it off and then on again all the fans light up there r 5 fans big 1 on the side 1 at front 1 at bottom 1 on back 1 on top they all come on with the lights theres no beep and it says on the screen no signal,the psu is not even a year old its a ocz 600w
            • atom157
              • Dec 2010
              try your monitor cable is plugged in to your graphic card
              • irishbluestaffy
                • 611
                every thing is in correct its screwed in tite
                • Hairlocks
                  • Dec 2010
                  • 9
                  Can you leave it off overnight. and then after your first power on, cycle the power every 15 minutes and note how long it lasts until it won't reboot.
                  Have you updated to the latest bios?
                  Which of your fans are blowing out, and which ones are blowing in?
                  • irishbluestaffy
                    • 611
                    ye i turn it off every night but when i turn it off it takes about 50 55mins to turn on i have to take the power lead off for it to work again i have tried many times after i have turned it off and it will not work unless its been disconected from the wall and left for the time stated
                    • dinosd
                      • Mar 2010
                      • 11
                      Even if your psu is new try to replace it.
                      The psu has 5 different output voltages.
                      The fans need 12v to operate. If the rest outputs are not good, the pc will not start but the fan and the power led will operate.
                      If you don't have a spare psu try this:
                      Remove all the power connectors from your fan, your optical drives. Also remove the data cables from your drives.
                      Leave only the 2 power connectors on your motherboard, the power of your hard drive and if exists, the power connector to your vga card.
                      Then, try to start your pc.
                      • cunny
                        • 4915
                        Sounds like a short somewhere on the psu, as suggested i would look to test/replace it
                        • irishbluestaffy
                          • 611
                          sorry peeps i forgot to say i changed the psu and all is working good now thanx for the help
                          • gsmalek
                            my frend try to change the power suplay box
                            • irishbluestaffy
                              • 611
                              i did and it works fine now
