adminstrator
  • cablefreejunkie
    • 1717
    adminstrator
    hi,i want to log on to my pc as admin so i can carry out a few tweaks,problem is on start up i only have myself as a user account
    how can i log on as admin ?
    im running xp media centre edition sp3
    any help much appreciated
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
  • Dreamer
    • 2020
    If you only have one account set up on the pc then you are already an administrator.
    If you have an admin account and then a seperate user account then go into the start menu and select shutdown, If you do not get the option to "switch user" then try this.
    once the pc has started up press the "ctrl, alt and delete" "buttons together. the Windows task manager should open up, then select the shutdown menu at the top and select "switch user".
    the other option is to go into the control panel into "user accounts" and select " change the way users log on and off" you will be able to see the user accounts which are available on your machine and can alter the way you log on initially
    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
    • caveman_nige
      • Feb 2008
      • 4920
      you need to see if you can give yourself admin rights.. have a read of this Make your account an Administrator in Windows XP
      There is another way to get to it. - Click on Start
      - Click Run
      - type lusrmgr.msc and click the OK button
      This will open the Local Users and Group window for you and you will then be able to make your account changes.
      If you get the access denied you will probably find that there is already a local admin account set up, first try ctrl-alt-delete, use the 'switch user' option, it should give you the admin option there, the password is could well be blank. I am not at an XP box right now so cannot try it besides I am local admin on all my office and home kit anyway.
      EDIT, I see Dreamer is on the case anyway at the same time..
      • cablefreejunkie
        • 1717
        sorted,,went to cp ,as dreamer said,,im admin anyway,didnt realise
        thanks for that peeps
