processor fault
  • irishbluestaffy
    • 611
    processor fault
    Intel Core 2 Duo E6700
    Windows 7 Ultimate Edition (Build 7600)
    CPU Arch : 1 CPU - 2 Cores - 2 Threads
    CPU PSN : Intel Core2 CPU 6700 @ 2.66GHz
    CPU EXT : MMX, SSE (1, 2, 3, 3S), EM64T, VT-x
    CPUID : 6.F.6 / Extended : 6.F
    CPU Cache : L1 : 2 x 32 / 2 x 32 KB - L2 : 4096 KB
    Core : Conroe (65 nm) / Stepping : B2
    Freq : 1599.95 MHz (266.66 * 6)
    MB Brand : Gigabyte
    MB Model : 965P-DS4
    NB : Intel P965/G965 rev C1
    SB : Intel 82801HB/HR (ICH8/R) rev B0
    this is a copy of a program i ran on my pc does any1 no why its highlighted in red,my processor has gone from 5.8 to 4.5 any help would b great thanx
    GPU Type : NVIDIA GeForce 8800 GTX (Microsoft Corporation - WDDM v1.1)
    DirectX Version : 11.0
    RAM : 4096 MB DDR2 Dual Channel
    RAM Speed : 400 MHz (2:3) @ 5-5-5-18
    Slot 1 : 1024MB (6400)
    Slot 1 Manufacturer : Corsair
    Slot 2 : 1024MB (6400)
    Slot 2 Manufacturer : Corsair
    Slot 3 : 1024MB (6400)
    Slot 3 Manufacturer : Corsair
    Slot 4 : 1024MB (6400)
    Slot 4 Manufacturer : Corsair
  • RedSpider
    • 2448
    at a guess, your processor may have an auto-clockdown feature try this...
    CONTROL PANEL > POWER OPTIONS > -- Select balanced (recommended)
    or select CREATE A POWER PLAN from the side panel and select HIGH PERFORMANCE and go through the motions of creating a new power plan.
    if you are already on a balanced or high performance plan then it could be underclocking due to overheating.
    Syntax Error : Integer Out Of Range
    Hooray For Tits & Fannies
    • irishbluestaffy
      • 611
      tried both ways it was set on balanced changed it to high,still the same is there anything else i could do,thanx
      • RedSpider
        • 2448
        perhaps try downloading the latest chipsets for your processor from intel
        • irishbluestaffy
          • 611
          dun that b4 still the same the pc itself seems to run the same as it did its just the base score has me worreid,thanx
          • RedSpider
            • 2448
            access your bios and reset the default settings. while in the bios, check the cpu temperature. if it is too high then it will automatically run slow.
            if its overheating, then clean it out. check your fan is running at optimum rpm. if its slowed then its not doing its job properly.
            also, while in bios, go into advanced bios features and disable C1E and EIST
            • irishbluestaffy
              • 611
              just tried that could only see c1e not the other,the temp of cpu is 22,i also downloaded burntest and checked the cpu and it said passed,pluss on the start up screens it says 1.60 ghz insted of 2.60,this is starting to realy confuse me,thanx for your help tho
              • RedSpider
                • 2448
                you sure? it should be there, maybe labelled as speedstep or something. list me everything in your advanced bios.
                you have a 64bit processor. are you running a 64bit OS?
                ...oh and feel free to click the scales under my profile pic as a way of thanks
                • irishbluestaffy
                  • 611
                  hi yes im useing 64 bit os windows 7 ultimate,
                  hard disk boot priority
                  first boot device
                  second boot device
                  third boot device
                  password check
                  limit cpuid max.to 3 disabled
                  no-execute memory protect disabled
                  cpu enhanced halt (c1e) disabled
                  cpu thermal monitor 2(tm2) enabled
                  virtualization technology enabled
                  init display first pci
                  • cunny
                    • 4915
                    Have you checked/done any bios updates?
                    Also as the bios posts first of, what does the CPU NAME AND CLOCK SPEED SAY?
                    Also what was the program you used to get the information
                    Also try downloading CPU Z Did you clean out your heat sink on the CPU
                    • RedSpider
                      • 2448
                      how odd, your EIST should be sat there right below THERMAL MONITOR.
                      try pressing CTRL + F1 as soon as you enter advanced bios, see if that unlocks that which should already be there
                      • irishbluestaffy
                        • 611
                        cunny it says processor intel(R) core(tm)2 cpu 1.60ghz,also i changed the heatsink last night and gave it a good clean with cpu wipes,also i downloaded that program ran it then it said validate it took me to a web page witch i coppeid which is at the top of this page but i dont no y its highlighted in red,redspidder i will try that now and c if i can get to it
                        • cunny
                          • 4915
                          So the info is from CPU Z?
                          Have a look on here to test the CPU
                          http://downloadcenter.intel.com/Deta...eng&iid=dc_rss
                          • irishbluestaffy
                            • 611
                            first off redspider i tried that and nothing happend,and cunny i downloaded that and run a test and it passed on everything,strange dont no whats goin on but i no its not right could it b the mb ???
                            • gregk
                              • 242
                              I see that you have a gigabyte MB have you got giga tune/overdrive tuning soft installed? Or something like that. this program will run in a back ground and if settings have been changed there. it will re set bios settings to whatever has been preset in that program and under clock your CPU. Open tuning soft and set it to default settings see if that works.
