Advent 5612 black screen dosnt boot up.
  • stewpot
    • 16
    was working on laptop,Advent 5612, Gool-maps the laptop went off, min later started to boot up (black screen) tried to boot for 35secs then went off 15secs started to boot up and it just repeats this cycle, Black screen 35 sec on 15 off. done batt thing, Batt fine, plug fine, took HD out no change, Took ram out no change, cant use cd to reboot dosnt work,screamed at it no change. anyone any ideas. have linked it to another computer no effect. stewpot
  • smokey_jnr
    • 380
    hey mate,
    did you manage to fix this issue..?
    i've got the same issue on Advent 5712...
    • stewpot
      • 16
      hi chum, no didnt fix, fault is 1.internal clock setting. goes to boot setting tells L/T (error shut down.) or video card which is fixed to Motherboard. so replace Motherboard on both counts. I have a 9 month old laptop ln a bag not used for two years, plastic still on it. tryin to get a GOOD motherboard at the right price then ill fix it. but time moves on techno gets better and this poor laptop its gettin old in its short life so thats the story so far. dont know if it helped, advent 5612 motherboard are nortorous for this fault, watch out when buyin second hand, buyer beware.
      goodluck
      stewpot
      Last edited by stewpot; 25 November, 2011, 20:10. Reason: 5712 motherboard is same as 5612
      • saggy
        • 25
        If you have no joy as yet try searching for "reballing in a oven" on google
        I fixed it using a heatgun but oven is just as good....
        Im guessing you turn it on and a few light come on and you hear the fan - then turns itself off - in a continious loop?
        • stewpot
          • 16
          ya mate thats it, boot loop, Iv had it in the freezer (Nothin). but heat gun naw havnt tried that, and stickin it in an oven it will end up like the rest of my cookin BURNT. Does it work, and is it a fix?.
          • saggy
            • 25
            Hiya
            Yeah I have done a few like this and always been lucky with a heat gun but its well easy to screw up yer chips
            Oven is probably the best way as its more gentle to heat up and cool down but i was in a rush......
            If its screwed you have nothing to loose eh. There are firms out there that will do it for you on a proper machiene but hey
            • stewpot
              • 16
              what is the process,Temp/time and do you strip motherboard out of laptop or just put the lot in oven, i take it there isnt a problem with the screen.
              • saggy
                • 25
                How to Reflow a Laptop Motherboard in a Household Oven | Computer Repair Tips
                looks like 200c for 8 mins is the way to go
                you must strip it down to nothing on the board and just bake the board on its own
                • stewpot
                  • 16
                  well i`l give it a go in a couple of days or so (nu born of 7wks in house taking up all time ) wee buns aah, i will let you know in due course what the outcome is ok chum thanks for info and good luck
                  • smokey_jnr
                    • 380
                    that's exactly whats happening. is there no other 'fix' apart from what you've mentioned above..?
