SETUP problem
  • jo?o antonio
    • 369
    SETUP problem
    H? people ,
    Do you need to reset the setup ?
    back to the original manufacture`s settings
    My problem is ( Boot sequence ), is bad , not show in setup.
    My PC is windows 98-se
    which tool to use , procedure ?
    Thanks.
  • Canker_Canison
    • 3904
    You need to change the boot sequence in your bios.
    Try hitting the 'del' key when either you here the pc beep on startup or you see the post screen. It might look like this...
    You should then see something like this...
    look through the menu's using the cursor keys until you find the boot sequence menu & make it so the C: drive is top of the list. This should ensure it boots correctly.
    If you set it so CD or DVD is top, USB second & C: drive third. You will need to make sure you have no bootable disks or USB drives plugged in.
    If you have more than 1 HDD, i.e. C: & D:, make sure they are listed in that order.
    Canker
    [COLOR=Green]
