HP G6000 no IDE Device found
  • mahabad1972
    • 39
    hi friend of mine had password in bios and forgot wasn,'t able to log in so i searched a google i foud solution by removing the RTC battery inside and leave for 25 minute then put back again, it did refresh the bios but now can not find operation system, when i go to bios for diagnostic it does not find ide device, also it won't put from cdrom too, it keep restarting and that is all i even changed battery but not work, also hard drive make noise , try to check the harddrive with external usb on different pc, but did not show the harddrive, need some help please
    HP G6000 notebook pc
    system board ID 30EA
    AMD Athlon 64x2
    Dual core Processor
    bios version F.05
  • dasteph
    • 1293
    AMD Athlon 64x2
    Dual core Processor
    bios version F.05
    ther is a recovery partition on your pc which you access by pressing f11 when it boots, it will take it back to its factory settings.
    • mahabad1972
      • 39
      I tried it already still the same it will restart again and says no operation system found it doesn't matter press any key
      • mastero
        • 8
        If the hard drive is making a clicking noise that means the hard drive is on its way out mate I can sell you a new hard drive if you want I own a computer shop
        Just give me the size of the drive plus if its ide and sata
          no buying/selling on dk !!!
          • mahabad1972
            • 39
            yes it does clicking i took the harddrive out used usb it didn't show up on my pc, , so i got a new hardrive now it does show on bios, but when i try to install new windows , id doesn't detect cdrom or either usb, to install and at the end said BOOT MGR is missing Press CTRL+ALT+DEL to restart, and sometimes said no operation system which is i know the harddrive is empy but why said missing boot mgr
            • Bazigar007
              • Feb 2011
              • 74
              check your cabl to the drive ... 1 pin was bent on mine and had same problem ... changed to spare cable and it came back on
