This is driving me nuts. I've still got things to try but looking for ideas.
Got a new PC with W7 already installed & activated. 64 updates already installed, so it has connected to the internet previously.
All my wi-fi dongles use the RTL8187L chipset. Latest W7 drivers are installed, dongle is installed & 'working correctly'.
I can scan for routers, select & enter password. The connections manager shows connected but no network access. The WLAN Utility shows the IP address as 168.xxx.xx.xx.x instead of 192.xxx.xx.xx.x, the subset mask is correct but no gateway (probably due to the incorrect IP address).
Tried 2 other connections that are open... Same thing.
Then installed the software for my mobile phone. Used the phone as a modem & got it showing on the network manager as OTA connected.... but it's also showing no network access.
Drivers & software have been removed/uninstalled, W7 restarted, drivers & software installed, W7 restarted... still not working.
The router is working as both my previous PC & my lappy (both on XP) have no problems connecting.
I'm not able to connect via cable at the moment, but W7 has been updated prior to my taking ownership so assuming for now that the LAN is working.
Next step will be to remove HDD's & install a spare HDD I can install XP onto. This is more to check the mobo is working correctly & the problem is in W7 somewhere.
Anybody out there with some knowledge of W7 wi-fi issues & solutions?
