Graphics Card help please
  • billy2
    • 1381
    hi guys need some help please got this card (MSI HD 4670 1GB GDDR3 DVI HDMI HDCP Out PCI-E Graphics Card) and wont to run it with 1 monitor and lcd tv have the monitor running with the D-SUB Output and wont to use DVI Output for the tv , thing is when i have the tv on monitor wont come on ???
    thanks for your time guys
  • dasteph
    • 1293
    in the control panel you might have a graphics control panel where you can set it to give you multiple displays.
    • Sirus
      • 340
      I'm using a 4850, and like dasteph said...
      ... it's in Control panel> Display> Settings tab> Advanced> Catalyst Control Centre> Displays Manager.. you can set it up from there.
      Or maybe you have a shortcut on desktop to Catalyst Control Centre, or even an icon at the bottom corner will bring it up too
      • stu martin
        what OS are you on? in W7 right click the desktop
        • billy2
          • 1381
          woking now thanks just had to clone monitor to tv
