newbie
  • atchu
    newbie
    hi all, i would like to say hi to all the kaos users, i am looking for synccell, or something similar to connect nokia 6220 to my laptop through bluetooth connection, i have used the trial synccell and it works, but it needs a cd key after the trial period? so if anyone has any software that should do the trick, much appreciated.
  • atchu
    sorry i forgot to mention its to connect to the internet thru mobile internet usage
    • Jim.Mahoney
      • Feb 2010
      • 4249
      Try looking for BlueSoleil although it's up to V8 or so, earlier versions are great for the task that you need! The newer versions only support extras like bluetooth headsets on your PC - Something most people don't need!
      The earlier versions 3 and below can often be found either cracked or with serial number.
      It's also very easy to use but do un-install any other bluetooth programs first!!
      This is a link to V
      6.4.249.0 with Key Maker! http://www.megaupload.com/?d=93UCWNSG
      Instructions:
      1, setup IVT BlueSoleil.v6.4.249.0
      2, open Keygen and enter serial to Activate (disconnect internet)
      3, open Activation Tool and enter same serial & get Activiation information
      4, now copy Activiation information
      5, now past Activiation information to Activiation url in keygen and generate Activiation Code & copy
      6, now enter Activiation Code in Activiation Tool and Activiation BlueSoleil
