Phone Tweaks
  • unadkat
    • 340
    Phone Tweaks
    Phone Tweaks
    Alcatel
    Master Codes
    - 25228352
    - 25228353
    - 83227423 (TH3/4,BH4,BF5,BG3,BF3/4..)
    ###337*07# - master reset (with SIM)
    ###847# - factory reset (with SIM)
    Alcatel 835 formating - **0102#
    Samsung
    *2767*3855# - FULL E2P RESET
    *2767*2878# - CUSTOM E2P RESET
    #*7337# - UNLOCK
    *2767*688# - UNLOCK
    *#0523# - CONTRAST
    *#9998*523# - CONTRAST
    *#8999*8378# - Service Menu (X100)
    Philips
    #20021208# ok - 630 without SIM (erase flash)
    *#7728*# - RSAV DONE
    *#3849*# - ??? reboot
    *#3851*# - ??? reboot
    Philips 568 *01763*737381# - reset
    Pantech
    *01763*737381# - master reset (user data, user code) without SIM
    *01763*8371# - SW version
    *01763*6371# - UNLOCK
    *01763*3641# - Menu
    Panasonic
    *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55..
    *369#(*) - MENU
    7, 4, 6, menu, menu - lock menu
    *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..)
    LG
    2945#*# - service menu (code resetW3000 G5300 C1200 G7100...)
    2945#(*)- hold (LG 500,600)
    B1200 *+pwr, 6,6,8 Service Menu
    B1300 *+pwr, 1,5,9 Service Menu
    Security Removing Code For Lg 8110,8120.
    47328545454#
    Or
    277634#*#
    Sony-Ericsson
    > * < < * < * - Service menu
    < * * < - Lock menu
    VK Mobile
    *#79# - SW version
    *#85*364# (*) - hold menu
    855855# without SIM (VG107)
    85558555#(*)-hold
    4268#(*)-hold (VG207)
    Voxtel
    0124 - master code
    0718#(*)- hold - menu (ST11, SC10, V100 without SIM)
    4268#(*)- hold - show code (ST11, SC10 without SIM)
    *789(#)- hold - menu (V50, V300, RX100 without SIM)
    Motorola
    (T190, T191, T205) master code
    - 19980722
    - 20010903
    P2K test menu:
    *#06#, menu, menu, 048263*
    Test comands:
    32*116*1*0*0 - read phone code
    32*118*1*0*0 - read security code
    18*0 - factory reset, phone code off
    18*1 - master reset
    54*18*1 - full phone reset
    10*0*6 - select 900/1800
    32*279*1*0*8 - model
    32*383*1*0*0 - flex version
    Hard reset MPX200, MPX220 - blue button + power on
    Nokia
    *#7370925538# (valet code reset) 6230
    *#746025625# [*#sim0clock#]
    *#92702689# [*#war0anty#]
    Fly Bird
    S688 - #*301#02# send - with SIM
    menu:
    7 - 10 - ok,
    #*8000#, #*3676# (reboot repair)
    V09, S1180 - *, 3 times down, 3 times up - service menu
    Enol
    *#987*00# - Service menu
    *#987*99# - Full reset
    *#900# - SW version
    Maxon
    *#9922# - menu, reset (without SIM)
    *#9900# - Software Version
    *#9901# - Software Version (PBatch)
    S60 Siries (SX1, 6600, N-Gage..)
    *#7780# - factory default
    *#7370# - full factory defaults (all user data reset)
    SX1 formating - * + # + power on
    6600 formating - 3 + * + send + power on
    Sendo X1 formating - 5 + power on
    Mitsubishi
    *65512890 (*-hold) format FFS (Eclipse)
    * 3926 - (*-hold) test mode
    * 5806 - (*-hold) SW version
    *(hold) 787090 - trium 320 unlock menu
    Huawei (cdma)
    MASTER SECURITY CODE
    -309296
    -3092
    -9296
    Pantech HX-550C (cdma)
    Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR,
    after reset - ##27732726 PWR and select "with uim"
    *#0000# Displays your phones software version:
    1st Line : Software Version
    2nd Line : Software Release Date
    3rd Line : Compression Type
    *#06# For checking the International Mobile Equipment Identity (IMEI Number)
    *#2640# Displays security code in use
    *#0000# Display Software ver. and compresion type
    *#100# Shows the phones number
    *#639# Programming - min/sid
    *#67705646# Removes operator logo on 3310 & 3330
    *#73# Reset phone timers and game scores
    *#7760# Manufactures code
    *#7780# Restore factory settings
    *#92702689# Displays:
    1. Serial Number
    2. Date Made
    3. Purchase Date
    4. Date of last repair (0000 for no repairs)
    5. Transfer User Data. To exit this mode you need to switch your phone off then on again
    *#30# Lets you see the private number
    *#94870345123456789# Deactivate the PWM-Mem (not recommend)
    *#746025625# Displays the Sim Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
    **21*number# Turn on "All Calls" diverting to the phone number entered
    **61*number# Turn on "No Reply" diverting to the phone number entered
    **67*number# Turn on "On Busy" diverting to the phone number entered
    *3001#12345# Programming / Field Test
    *#21# Allows you to check the number that "All Calls" are diverted to
    *#61# Allows you to check the number that "On No Reply" calls are diverted to
    *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
    *#67# Allows you to check the number that "On Busy Calls" are diverted to
    *#43# Allows you to check the "Call Waiting" status of your phone.
    #3370# Enable Enhanced Full Rate Codec (EFR)
    #4720# Disable Half Rate Codec (correct code)
    *#1345# Shows credit value
    *** to the P sign
    **** to get the W sign
    ***** to get the + sign
    *#147# This lets you know who called you last (Only vodofone)
    *#1471# Last call (Only vodofone)
    *#21# This phone code allows you to check the number that "All Calls" are diverted to
    *#2640# Displays phone security code in use
    *#43# Allows you to check the "Call Waiting" status of your cell phone.
    *#67705646# Phone code that removes operator logo on 3310 & 3330
    *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
    *#8110# Software version for the nokia 8110
    *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
    12345 This is the default security code
    press and hold # Lets you switch between lines
    Software version *#2820#
    M aster reset *73738#
    SP lock *#3210#
    Cooprate lock *#8140#
    SIM lock *#4960#
    Net Lock *#7320#
    E616 get the P sign
    P sign will appear after the # is held pressed for 3 seconds
    Temp unlock solution working on older firmwares please only try once.
    To unlock using temp solution Use any 2G simcard and turn-on the phone pre feb 2004
    1) #4960*xxxxxxxx# + Send
    2)*4960*xxxxxxxx*xxxxxxxx# + Send
    3) Turn-off the phone and turn-on again!
    xxxxxxxx = any numbers make sure you keep them the same
    *2767*JAVA# Java Reset and (Deletes all Java Midlets)
    *2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
    *2767*WAP# Wap Reset
    *2767*CUST# Reset Custom EEPR0M
    *2767*FULL# Reset Full EEPR0M (Caution)
    For example : *2767*JAVA# would be keyed in as *2767*5282#
    *#06# IMEI code
    *#9998*4357# Help Menu
    *#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
    *#9999#0# Monitor Mode
    *#9999# or *#9998*9999# Software Version
    *#8888# or *#9998*8888# Hardware Version
    *#9998*746# or *#9998*0746# or *#0746# Sim Infos
    *#9998*523# or *#9998*0523# or *#0523# Display Contrast
    *#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
    *#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
    *#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
    *#9998*377# or *#9998*0377# Error log
    *#9998*778# or *#9998*0778# or *#0778# Sim Service table
    *#9998*782# show date and alarm clock
    *#8999*638# show network information
    *#9998*5646# change operator logo at startup
    *#9998*76# production number
    *#9998*968# view melody for alarm
    *#9998*585# Non-Volatile Memory (NVM)
    *#3243948# Digital Audio Interference Off
    Try these at your own risks
  • alunfennell
    • Oct 2008
    • 1525
    Found your information realy helpful
    Regards:
    Alun
    **The Worlds Best Interactive F1 Strategy Game**
    • manfios
      • 7
      nice tweak
      • freedom.paddy
        • 7
        cheers save me a bit of trouble
        • dannk83
          • 9
          will dig sum old phones out and have a play. ty
