blackberry wont turn on
  • jordigirl
    • Oct 2011
    • 716
    any help would be appreciated,
    was my sons phone, was working fine a couple of weeks ago, he got a new 1 so a put it in a drawer, got it out to flog today and it wont turn on, have tried charging it no good??
    thanks in advance
  • samlen27
    • 168
    if u connect it to blackberry desktop software does that see it,might need software reinstalling on it.or u could try a new battery if all else fails
    • rayjay
      • 461
      thanks in advance
      if the red light come on take battery out plug into charger and wait a little bit the fone will half boot and will say the battery not inserted leave charger in an put battery in after this will sort the boot cycle out but i would update via desktop etc
      • jordigirl
        • Oct 2011
        • 716
        hi thanks for advise a plugged it into lappy waited till red light went out and pulled out battery, put it back in and got it to boot up after several attempts
        thanks again
        • jordigirl
          • Oct 2011
          • 716
          got the blackeberry working again thanks for advice, seems all fine now,
          just 1 more thing though how ya change the time n date n stuff on it thanks
          • rayjay
            • 461
            cool just keep it charged now and it will be fine
            • Jim.Mahoney
              • Feb 2010
              • 4249
              Here is a generic reply as you don't state the Blackberry model...
              Press Blackberry Button and scroll to Options (a spanner icon)...
              Press OK button
              Scroll to Date/Time
              Press OK button
              Change 'Use Network Time: ' to No
              Scroll to Time and set correct time.
              Scroll to Date and set correct date.
              Press Back Button and Select Save
              If you have BIS enabled you shouldn't need to set manually...
              • rayjay
                • 461
                Press OK button
                Scroll to Date/Time
                Press OK button
                it normally lets you just change the date and time after initial boot up so if you get stuck pull the battery and let it reboot up
