faulty blackberry
  • tamgunner
    • 691
    faulty blackberry
    hi all im thinking of buying a faulty blackberry 8900 which doesnt charge apparently it charges when connected via usb but doesnt charge when connected to the mains.
    any ideas if its an easy fix?
  • Canker_Canison
    • 3904
    In the ideal world that would mean the charger is ~~~~ed.
    But I doubt it will be that easy.
    Worst case is a buggered charge port, not uncommon in blackberrys, an external charger & second battery will have it working.... if you can live with having to change the battery every day.
    Canker
    [COLOR=Green]
    • tamgunner
      • 691
      thats what i was thinking cause if it charges on usb fine i wouldnt thought it was a buggered charge port.
      • Canker_Canison
        • 3904
        It can still happen. USB cables are usually a little more substantial than the chargers. It's possible that the USB cable manages to keep the port legs in contact with the board, where the charger connector is pants & just causes more damage.
        But on the other hand, the seller could be a moron.
        Canker
        [COLOR=Green]
        • rayjay
          • 461
          if you want to get a cheap blackberry then just buy one with a white screen and put new one in or a fualty keypad it defo looks like the charger is at fault as the usb uses same pin out for usb and mains no difference same voltage so its the charger
