were can i find IDT C03?
  • bibolo2002
    • Sep 2012
    • 6
    Hello everyone, this is my first topic..... i want to give good luck to alla friends in the forum.
    Sorry were can i find IDT C03 for coinnect my M88++ whith inside win mobile whith my PC for change the ROM?
    thanks a lot
    Bibolo2002
  • rayjay
    • 461
    thanks a lot
    Bibolo2002
    better to write info requests in a language that others may understand
    • bibolo2002
      • Sep 2012
      • 6
      Sorry, but i don't understand in what lenguage i must write and in what section, sorry but i'm new.
      thanks a lot
      Bibolo2002
      • Jim.Mahoney
        • Feb 2010
        • 4249
        thanks a lot
        Bibolo2002
        English. Why not ask a friend to translate your question for you?
        • Canker_Canison
          • 3905
          thanks a lot
          Bibolo2002
          In english I think it means......
          I need an IDT C03 data cable so I can flash my chinese iphone copy M88++ phone with software that will probably brick it.
          Canker
          [COLOR=Green]
          • Jim.Mahoney
            • Feb 2010
            • 4249
            That is madness!
            There are multiple versions of this handset using various CPU types and Flash chips and each has its own flash file version. Get it wrong and the phone will be killed.
            As a minimum you will need something like Infinity Box and cable adaptors so you can at least make a full back up before you start to flash the phone...
            Once you get involved working with Chinese phones you get to realise that each town in China makes their own version of the same (in appearance) handset!
            • bibolo2002
              • Sep 2012
              • 6
              thanks a lot but which software i must use for back-up my phone?
              And what is Infinity Box and cable adaptor?
              thanks Bibolo2002
              • Jim.Mahoney
                • Feb 2010
                • 4249
                thanks Bibolo2002
                Infinity Box comes with software & cables...
                Cost is around 185 Euro / $235 / ?145 plus delivery.
                Probably a little expensive unless you have a 50 or 60 handsets to do!
                If the phone is working, then leave it alone or you may end up with a brick!
                • bibolo2002
                  • Sep 2012
                  • 6
                  the problem of my phone is that the dispaly is totally misaligned, so i think tochange rom because when i try to make hard rteset it not make it but it only start but after i cant use it because the touchscreen is not aligned.
                  thanks a lot
                  Bibolo2002
                  • Canker_Canison
                    • 3905
                    That is not a software fault.
                    What I think you're describing is a faulty digitizer.
                    An example of this would be when you press the 3 key the 1 key flashes & is entered into the phone.
                    If that is the case, the phone is useless. Spare parts are as rare as unmolested sheep in wales.
                    Canker
                    [COLOR=Green]
                    • bibolo2002
                      • Sep 2012
                      • 6
                      yes, i think that you center the problem, i have a Chinaphone M88++ and i can't make the hard reset, so before leave my phone i want to flash it....
                      you know other software to charge new rom in it, because i have new rom.
                      thanks a lot
                      Bibolo2002
                      • Jim.Mahoney
                        • Feb 2010
                        • 4249
                        thanks a lot
                        Bibolo2002
                        Take it to a dealer, writing a new ROM will NOT fix your problem!!
                        If it's not a hardware problem then it's corrupt calibration data (quite common on Chinese phones) and you'll need at least a Infinity Box to do such a job.
