Huawei Firmware error
  • shahnoor
    • Apr 2012
    • 20
    dear i need help in Huawei e5832
    last night i updated firmware but after reboot my device dont shows any light
    in device manager it detects only as modem
    i tried to update again but every time it failed
    i tried to reset by pressing connect and power keys
    but nothing shows up .
  • Jim.Mahoney
    • Feb 2010
    • 4249
    Did you use the correct flash file?
    Is it working as a modem?
    • shahnoor
      • Apr 2012
      • 20
      it was for e583x but i think actually it was e5832s firmware
      device manager detected as modem but connection manager cant find the device
      only device manager showing as modem .
      when i plug usb cable after couple of mints connection manager appears but do not show any device connected
      • shahnoor
        • Apr 2012
        • 20
        here is the SS when now again i try to change firmware
        but cant continue
        • Jim.Mahoney
          • Feb 2010
          • 4249
          If you have the CORRECT firmware for the device, it should allow you to force flash the device...
          Find out what device you really have and download the correct firmware here: DC Files - Huawei
          • shahnoor
            • Apr 2012
            • 20
            i already check that one and downloaded
            E5832_Update_676.11.00.20.112sp05 and another one also
            it can detect the device , take some time for updating firmware but progress bar do not move at all and ends with error " can not continue etc
            there is no option for force update
            • Jim.Mahoney
              • Feb 2010
              • 4249
              If you are using Windows 7 - Try updating using a Windows XP computer... You'll need to install a PC copy of Mobile Partner for the drivers first.
              • shahnoor
                • Apr 2012
                • 20
                i tried windows Xp also but same result
                • Jim.Mahoney
                  • Feb 2010
                  • 4249
                  Then, I'm sorry to say that JTAG is your only method and that's expensive as you'd need to buy the unit! Pointless for just one modem!!
                  • shahnoor
                    • Apr 2012
                    • 20
                    dear is there any unofficial firmware updater by using bin file ?
                    • Jim.Mahoney
                      • Feb 2010
                      • 4249
                      Only via JTAG method and you'll need the tool to do this!
