anyone know about HTC P3300
  • mini
    • 602
    I'm trying to format the HTC P3300 but I'm unable to. Everytime I try it says 'Format is Failed', it was working earlier but now it just gets stuck on the boot up screen and goes no further.
    Any and all help much appreciated, thank you.
  • Jim.Mahoney
    • Feb 2010
    • 4249
    Have you tried the reset button? You'll need a pin to poke in the hole!
    If that does not work, then you are left with a full factory reset:
    1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
    2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: ?Press Send to restore manufacturer default, or press other keys to cancel.?
    3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
    • mini
      • 602
      Yeah I tried hard reset and it says 'format failed'..
      • Jim.Mahoney
        • Feb 2010
        • 4249
        Probably your only route now is to flash the ROM. Sadly all of the locations that I had for HTC ROM's were on Megaupload!
        I'd suggest a bit of searching on Google, you might get lucky or sell it on E-Bay as needs attention...
        • mini
          • 602
          got it sorted, had to re-flash with original rom.
