E5832 PC connectivety problem
  • shahnoor
    • Apr 2012
    • 20
    i recently updated e5832 firmware
    update was successful but modem wireless not working
    even no modem appears in device manager .
    Lan also showing disconnected
    mobiles partner also can not detect the device
    please any suggestion ?
  • Jim.Mahoney
    • Feb 2010
    • 4249
    Have you tried a Factory Reset on the device?
    • shahnoor
      • Apr 2012
      • 20
      yes i tried . even i tried to install another firmware
      all lights on device are working.
      some time Pc detect modem even i can access The config page 192.168.1.1
      but lan shows as disconnected
      • Jim.Mahoney
        • Feb 2010
        • 4249
        Have you tried putting new settings in the set up page? If you have flashed unbranded firmware then the settings will be blank!
        • shahnoor
          • Apr 2012
          • 20
          dear setting is not a problem .
          problem is that device's wireless in not working even its enabled
          and the Modem does not appear in device manager . only com ports and Lan detected , but lan also not connecting
          btw i tried both firmware from DC files web site
          and another firmware from Egypt Etisalat mobile ( which must have config file )
          • Jim.Mahoney
            • Feb 2010
            • 4249
            If you can connect to 192.168.1.1the the Wi Fi is working!
            Try it on another PC and if it works on another computer then fully uninstall all Huawei programs from your PC and reboot before trying again...
            • shahnoor
              • Apr 2012
              • 20
              i tried other systems .
              its not every time that i can access 192.168.1.1
              and if i do because of USB cable connected .
              there are no WLAN signals even the Blue light on device is working and wlan is also enabled in 192.168.1.1
              usb lan also disconnected
              • Jim.Mahoney
                • Feb 2010
                • 4249
                You still don't say what device it is?
                D5832 or E5832s ??
                • shahnoor
                  • Apr 2012
                  • 20
                  D5832 or E5832s ??
                  E5832
                  • shahnoor
                    • Apr 2012
                    • 20
                    dear m waiting for your ans >
