blackberry 9300 Reload software : 507 problem
  • wahye
    • Aug 2012
    • 125
    hello to all DK members
    i have a big problem with a blackberry curve 9300
    i have make this but now i have a problem 0X0000000
    Preparation
    1. BACKUP all your data (Full BackUp) - IF YOU STILL ABLE TO
    ACCESS YOUR BLACKBERRY MegaStoon.Com - Work Online And Get Incomes Up To 1500$ weekly
    /?share=163921
    2. Download BSAK 1.9 : BlackBerry Swiss Army Knife
    3. BlackBerry Desktop Manager 6 : https://www.blackberry.com
    /Downloads/...
    4. Download OS
    BlackBerry - 404 Error - Page not found - US...
    Asia Pacific
    Choose from Maxis, DiGi or Celcom
    Choose Your Device (if you can't find, check below)
    OR
    http://www.blackberryos.com/forums/do... (You need to register
    first)
    A. For WIPE and Reinstall OS.
    1. Install BSAK
    2. Install Desktop Manager (if you haven't do so)
    3. Connect your Device with BSAK via USB
    4. In BSAK click on Wipe Device
    5. After done, your device will restart and leave Error 507...
    No worry, this Error means you need to reinstall OS
    B. Reinstall OS
    1. Install the *.exe files
    2. Go to c:\program files\common files\research in
    motion\apploader and delete the file named "vendor.xml."
    3. Plug in BB using USB and double click on "Loader.exe." It's
    located in the same place as the above vendor.xml file.
    4. When you receive a confirmation message that
    the experience is years + years of work !
    don't forget THANKS + REPUTATION
    if my post was helped !
  • wahye
    • Aug 2012
    • 125
    the problem was : reload soft 507 and when i try to update my blackberry the loader can't connect to rom !! it give the error 0x0000000 , but i have solve that problem when the blackberry want redemarre i disassemble and reassemble the battery , and when it would demarre again i disassemble and reassemble again and it comming connect to rom
    Best Rgards
    wahye
