FREE Huawei Modem Unlocking codes
This topic is closed.
Please help me
This morning I tried to update my firmware.setelah my modem firmware update can not be used. setap times in the plug into the usb port always appears warning me put the wrong sim card.
My modem is
e1552 huawei telecom globe tattoo
imei: 353143033135651
s / n: Y94CAA1982801444
Can my modem back to normal?
please help me
thank you very much earlierComment
353143033135651This morning I tried to update my firmware.setelah my modem firmware update can not be used. setap times in the plug into the usb port always appears warning me put the wrong sim card.
My modem is
please help me
Flashing: 44344037
Unlocking: 51651664Comment
I apologize for incorrectly entered imei, imei the first one turned out to be contained imei modem hardware. but after I check with Huawei Modem Software Code Writer v1.0b error instead.
and it turned out imei changed after I updated firmware.
so the firmware imei is
353143033133654
353143033133654I apologize for incorrectly entered imei, imei the first one turned out to be contained imei modem hardware. but after I check with Huawei Modem Software Code Writer v1.0b error instead.
353143033133654
Flashing: 40635997
Unlocking: 56807186Comment
why was not I? I was right when memasuukan imei and unlock code.
Send Unlock Command... ERROR
Found Phone, Phone Info:
- Manufacturer :huawei
- Model :E1552
- Revision :11.608.13.00.158
- Phone IMEI :353143033133654
Send Unlock Command... ERRORComment
If 10 x wrong code then no unlock!
You could try here: Dc-unlocker | Huawei E230, Vodafone Huawei K4505, Sierra Wireless USB301, USB302, Longcheer WM71, 4G Systems XSStick W14, MF100 Kyivstar
Not free but 100% reliable!!Comment
E220 does not normally unlock via code!
Try this code ONCE and post result!
Unlock: 61571478
If no go then go to the link given in post above!
To select new provider just set up a new profile. You may want to upgrade your dashboard to a generic one, these can also be found at the link given above!!Comment
is there any other way, just because my phone reeller in Jakarta, he again could not.If 10 x wrong code then no unlock!
