hi just got a samsung pixon yesterday its unlocked but has all or***e software all over it . can any body help me with any software to de brand it and take it to original software?
any body know how to de-brand my samsung pixon
Tags: None
First thing to always remember, is BACK UP YOUR PHONE, Pictures,wallpapers,music, and any contacts you have saved on your phone. I am not responsible for any damage to you, your phone, computer, or lost of data in this process. This is a guideline intended for professional technicians.
USE AT YOUR OWN RISK!!!
1. USB cable that came with your phone.
2. Samsung PC Studio 3 witch can be found here:
http://www.samsung.com/uk/support/d..._ia_cd=01011800
Install this software first, it contains the drivers for your phone, and has every thing you need for backup.
3. Multiloader v5,50 http://www.4shared.com/file/75565159...ader_V550.html
5. Newest unbrranded firmware
4shared.com - online file sharing and storage - download M880BXXIE1.rar
-----------------------------Now you are ready to begin-----------------------------------
1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it.
2. Remove the Sim and MicroSD from your phone and replace the battery.
3. With the phone OFF connect the phone and computer with the USB cable.
4. While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says "Download" ( For Tocco and Pixon users : Hold down the "Volume -" button on the left side, and the "Camera" button on the right, then press the "Power" button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.)
5. Now run MultiLoader v5.33
6. Select the radio button that includes MSM6275/MSM6280.
7. Select Boot Change and Full Download.
8. Then click Boot, and select the boot files from the unpacked firmware folder.
9. Click the Amss, Rsrc1, and Rsrc2.
10. Then press the Factory FS tab, and select the appropriate files from the firmware folder also.
11. Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid)
12. FOTA and ETC fields are left blank.
13. Click the Port Search button, it will find your phone and show the com port is ready.
14.Click the download button and be patient, this will take a few minutes to complete.
15.When it's finished, it will show "ok complete".
16.Unplug the phone from the USB cable, reinstall the sim, MicroSD, and power up the the phone.
17. Now with every thing complete, perform a hard reset by typing *2767*3855# into the hand set.
18. When the phone resets type *#1234# into your handset to check your new firmware ver. -
HELP
I attempted the reboot on my samsung tocco and have had a problem. I was trying to get rid of the vodaphone settings which had locked my internet even though the phone was unlocked. I got as far as undergoing the reboot had the correct message on the phone. The download started got the wait reset line and then got an error massage Serial Port detect error. Phone will not turn on at all. Can you help
ThanksComment
As with your other post, go here for all the software you need.
Also try an earlier firmware & don't use a cooked firmware until you've got it working.Canker
the reason why your phone will not start up is because there is a problem with the boot loader (mismatch) try another firmware preferably one with the letter x in it as that will have english langaugedm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt routerComment
