Nintendo Ds (Howcan i play Movies on it )
  • BRASS EAGLE
    • 307
    hi got the grand wains DS,i can get games onto it but when i transver music videos or small movie files onto the 2gig card it doesnt play them,any help is appreciated
  • dinocol
    • 25
    you need a flashcart to do it.. probably R4 and install moonshell on it. you'll be able to play mp3 and movies then..
    • nocrap
      when can this be got from?
      • barrowmanandrew
        • 3427
        you need to put moonshell on to your microsd card, this will play .dpg movies.
        • BRASS EAGLE
          • 307
          Its a R4 card when i check the properties on it a.its got moonshl,and moonshl2 on it, i down loaded a Lady Ga Ga clip for her but it only plays the sound not the video.? I will check the down load again as it might be only a mp3 Cheers for your info
          • gji25
            • Feb 2010
            • 353
            you need to convert the video file to Convert any supported input file to a (.dpg) Nintendo DS file.
            The rendered Nintendo DS files are created using a fully compatible DPG format.
            you can use a program called super to do this
            dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
            • shitfabraynz
              • Sep 2009
              • 21
              you can also use a program called "dvd fab platinum", also good for shrinking to ipod and backing up dvd's easily.
              its my midlife crisis and ill paint my brake calipers red if i want to!!!!
              • BRASS EAGLE
                • 307
                is it just called super?
                • didolebon
                  • Jul 2010
                  • didolebon
                    • Jul 2010
                    hi, you should use BatchDPG to convert videos to .dpg and use moonshell to watch it
