Free Huawei Online Codes Flash & Unlock - New Thread
This topic is closed.
  • Jim.Mahoney
    • Feb 2010
    • 4249
    #616
    Originally posted by sdmmvvja
    Hi!
    I am new to this forum. On my model it was written on the back of the device. But i have seen that your model does not have it there.
    What i have seen while i tried to flash mine, is that the firmware update tool shows you the IMEI. So i would suggest you to download it, start it and when it detects the device, you will see the IMEI number. At least that was it fo my model (E122).
    I hope that helped.
    You have a E122 but he has a EC122 and the latter is CDMA, that means not GSM/UTMS and as such this has a ESN (electronic serial number) like analogue phones did back in the 90's in Europe!
    • julka01at
      Please help me to unlock:
      Huawei E1552
      IMEI: 358812034495024
      • Jim.Mahoney
        • Feb 2010
        • 4249
        #618
        Huawei E1552
        Selected Modem: E1552
        Phone IMEI: 358812034495024
        Calculating Codes...
        UNLOCK CODE : 58520978
        FLASH CODE : 64995054
        Codes Calculated OK...
        Done.
        • sdmmvvja
          • Feb 2011
          • 14
          #619
          Oh, sorry did not know that this type of device does not have such a IMEI number at all.
          Thought it is simply not printed on the back of it. Sorry for that. Only wanted to help. :-(
          • sdmmvvja
            • Feb 2011
            • 14
            #620
            By the way, I would also need a unlock / flash code. :-)
            My device details are:
            Huawei E122
            IMEI: 356881034851710
            • Jim.Mahoney
              • Feb 2010
              • 4249
              #621
              Huawei E122
              Selected Modem: E122
              Phone IMEI: 356881034851710
              UNLOCK CODE : 54834535
              FLASH CODE : 67001508
              Done.
              • demonwolf2009
                • Feb 2011
                hi there can I have the unlock code for the following device please
                hauwei e180
                imei: 354241027382441
                • Jim.Mahoney
                  • Feb 2010
                  • 4249
                  #623
                  hauwei e180
                  You must have five valid posts at this forum (code requests do not count) or You must have been a member for at least 30 days!
                  • bnad3m
                    • Aug 2009
                    • 150
                    #624
                    Hi, can i have unlock code for this device please !
                    huawei : E156G
                    EMEI : 357133031234667
                    • Jim.Mahoney
                      • Feb 2010
                      • 4249
                      #625
                      huawei : E156G
                      Selected Modem: E156G
                      Phone IMEI: 357133031234667
                      UNLOCK CODE : 39917542
                      FLASH CODE : 55616165
                      Done.
                      • canser
                        • Aug 2009
                        • 7
                        #626
                        Originally posted by Jim.Mahoney
                        Here we offer Free Unlocking Codes for Huawei 3G/HSDPA/HSUPA Modems.
                        Most modems are supported except the E220.
                        Model: E180
                        IMEI: 354241025294317
                        Thks in advance.
                        • Jim.Mahoney
                          • Feb 2010
                          • 4249
                          #627
                          Originally posted by canser
                          Model: E180
                          Thks in advance.
                          Selected Modem: E180
                          Phone IMEI: 354241025294317
                          UNLOCK CODE : 50596949
                          FLASH CODE : 42765349
                          Done.
                          • canser
                            • Aug 2009
                            • 7
                            #628
                            Unlock code
                            I have another HuaWei USB modem, I need the unlock code.
                            Model: HuaWei E153u-2
                            IMEI: 352374043179202
                            Another problem is that the CD-emulator is having problem, driver cannot be read or install. All the files name can be listed out, but cannot run or copy out.
                            Is there any way that I can repair / restore / completely delete it away?
                            Thanks again.
                            • Jim.Mahoney
                              • Feb 2010
                              • 4249
                              #629
                              Thanks again.
                              Selected Modem: AutoSelect
                              Phone IMEI: 352374043179202
                              UNLOCK CODE : 36137577
                              FLASH CODE : 58291620
                              Done.
                              Please post the result on this code as the E153 is quite new, if it doesn't work don't keep trying!
                              Autorun from the CDROM emulation can be turned on and off. Rather than get you to type long codes using Windows Hyper terminal you'd be best to download a copy of MDMA here:
                              MDMA - a Mobile Data Monitoring Application
                              Establish the COM Port that your device is using in Device Manager under Modem of course!
                              If you modem is using say COM 6 then run MDMA like this:
                              MDMA /port:COM6 /u2diag:1
                              • canser
                                • Aug 2009
                                • 7
                                #630
                                Thanks, I look into it
