Blackberry bold 9000 problems!
  • Irish grower
    • Mar 2010
    • 20
    Hi was wondering could I egt some help. I have a BB 9000 when I put the battery in red light comes on for about 10 seconds then knocks off if I push any button on the phone what happens is the trackball lights up then second later the laypad then the screen but I can't see anything.
    It's a bright colour it's like a very light green / white colour. I thought it was the screen but I tried the screen in a mates phone and it worked I have the rigth screen for mine just phone doesn't work it won't turn off then intil I take battery out.
    I tried removing screws and pressing around the screen but still nothing.
  • Canker_Canison
    • 3904
    Think you'll need to take it in for repair.
    Just so you know this...... All Blackberrys when turned off do not turn off. They just go into a power saving mode. If you want to turn it off you have to remove the battery & leave it out.
    Your problem sounds like water damage or software issue.
    Canker
    [COLOR=Green]
    • Irish grower
      • Mar 2010
      • 20
      Could a phone shop do this or would I have to send to blackberry?? I mean a shop that does unlocks etc be able to fix it.
      • Canker_Canison
        • 3904
        Either, but I'd try the official route first. If it comes back as water damaged & not covered by the warrenty, try an unlocking shop with a good reputation
        Canker
        [COLOR=Green]
        • ironberry
          RE:
          I think you should take it to a repair shop to get fixed. I had the same particular issue and did the same thing.
          I used this repair company called: blackberryplace.com
          pretty good.
          hope this will be of help to you.
